Old 08-02-2012, 08:45 PM   #1
Zadkiel
Drives: CBS BRZ Limited 6MT
Foglight replacement help
I was wondering if anyone has replaced the OEM PSX24W foglights with an aftermarket unit. I keep reading horror stories about melted housings and wanted some clarification before I bought an LED replacement.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 08-03-2012, 02:02 AM   #2
KI_ZN6
KI_ZN6's Avatar
A customer of ours have installed our HID conversion kit with 6000k bulbs for a few months and have not experienced any issues with heat/melting, etc. We assisted him with the installation, so you may want to PM him to get his opinion/confirmation. His screen name is "jmah88".
KI_ZN6 is offline   Reply With Quote
Old 08-03-2012, 02:42 AM   #3
jmah88
Drives: 2013 SUBARU SWP BRZ
Hi Zadkiel,
I installed an HID kit for my fogs and have had no problems!! The color better matches my Headlights at night and I have even better visibility in bad weather conditions! It was pretty easy to install, and the housing units are holding up sturdy, so I dont think you need to worry!
jmah88 is offline   Reply With Quote
Old 08-06-2012, 10:51 AM   #4
HIDWerks
Drives: 2009 Cobalt SS Turbocharged
HID run cooler then halogens. You wont have any issues running a HID setup.
HIDWerks is offline   Reply With Quote
Old 08-06-2012, 11:11 AM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The stock bulbs are essentially 24W brake light bulbs with a fancy base, so a 35W HID kit is still a bit warmer. But It's good to know that someone has done it without issue so far.
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
which H11 replacement bulb 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 13 07-18-2012 10:23 AM
OE Replacement Dampers Sccabrz192 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-08-2012 11:52 AM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 12:47 AM
