Old 01-12-2015, 05:47 PM   #1
Cvxne
Cvxne's Avatar
Drives: 2013 Whiteout FRS
Car won't turn on.
Hey guys so I haven't driven my car since thursday and today I went to go start it and nothing will turn on. The doors won't even unlock. Could it be the battery? My car only has 15,000 miles and I recently installed the Buddy club JDM tail lights but those were plug and plug and I've had other tail lights such as TOMS on my car before with no issues. I tried hooking up spark plugs to the battery and the lights came on but then the car died again. I then tried a second time and nothing. Anyone have any input?
Cvxne is offline   Reply With Quote
Old 01-12-2015, 05:51 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Check your battery with a multimeter, check your fuses, check your alternator, the basics.
Old 01-12-2015, 06:00 PM   #3
Cvxne
Cvxne's Avatar
Unfortunately I don't have a multimeter but I checked the fuses and the alternator and they were fine.
Old 01-12-2015, 06:04 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its almost certainly the battery. This happened to me a while back although my car was unlocked. I turned the key and nothing, not even a click, bought another battery and fired up just fine.
Old 01-12-2015, 06:11 PM   #5
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
^Second If you cant even operate your doors with your remote, thats your battery.
Sugi is offline   Reply With Quote
Old 01-12-2015, 06:42 PM   #6
Cvxne
Cvxne's Avatar
I'm going to go buy a new battery tomorrow and see what happens.
Old 01-12-2015, 06:57 PM   #7
cnk
Drives: '13 DGM BRZ Limited
Did you close your trunk completely? I killed my battery the other week when the trunk wasn't closed all the way. Charged it back up and it's been fine.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 01-12-2015, 07:02 PM   #8
evan
Drives: fr-s
Do you have jumper cables and a friendly neighbor?
Also, get yourself a multimeter. It will pay itself off hundreds of times over.
evan is offline   Reply With Quote
Old 01-12-2015, 07:05 PM   #9
swarb
with a sig of your bmw.... the frs knows you love the bmw more, so she tried taking herself out of life support. (the battery)
Old 01-12-2015, 07:31 PM   #10
strat61caster
strat61caster's Avatar
Probably don't need to buy a battery, jump the car and drive it for an hour to charge it up, figure out if you have a fault in the system first, even the most competent of master mechanics make mistakes.
Old 01-13-2015, 10:19 AM   #11
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Buy a multimeter while you're there!
billwot is offline   Reply With Quote
Old 01-13-2015, 10:34 AM   #12
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
H I tried hooking up spark plugs to the battery and the lights came on but then the car died again.
What the balls?
SloS14 is offline   Reply With Quote
Old 01-13-2015, 12:06 PM   #13
Cvxne
Cvxne's Avatar
I bought a Diehard battery and now the car runs perfectly.
Old 01-13-2015, 12:20 PM   #14
Just an FYI! Us Northerners can have the horrible experience of a battery freezing if it goes flat when really cold. So replacement of a dead flat battery in below zero temperatures is just a fact of life.
Correct that he needs to check it out even though a new battery "fixed" it. Something caused it to go flat and recently installed tails is some pretty convincing evidence even if just plug and play!
car won't start
Tap Turn thorlius Electronics | Audio | NAV | Infotainment 304 09-29-2016 03:21 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 02:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
