Old 01-12-2015, 05:47 PM   #1
Cvxne
Cvxne's Avatar
Drives: 2013 Whiteout FRS
Car won't turn on.
Hey guys so I haven't driven my car since thursday and today I went to go start it and nothing will turn on. The doors won't even unlock. Could it be the battery? My car only has 15,000 miles and I recently installed the Buddy club JDM tail lights but those were plug and plug and I've had other tail lights such as TOMS on my car before with no issues. I tried hooking up spark plugs to the battery and the lights came on but then the car died again. I then tried a second time and nothing. Anyone have any input?
Cvxne is offline   Reply With Quote
Old 01-12-2015, 05:51 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Check your battery with a multimeter, check your fuses, check your alternator, the basics.
Old 01-12-2015, 06:00 PM   #3
Cvxne
Cvxne's Avatar
Unfortunately I don't have a multimeter but I checked the fuses and the alternator and they were fine.
Old 01-12-2015, 06:04 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its almost certainly the battery. This happened to me a while back although my car was unlocked. I turned the key and nothing, not even a click, bought another battery and fired up just fine.
Old 01-12-2015, 06:11 PM   #5
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
^Second If you cant even operate your doors with your remote, thats your battery.
Sugi is offline   Reply With Quote
Old 01-12-2015, 06:42 PM   #6
Cvxne
Cvxne's Avatar
I'm going to go buy a new battery tomorrow and see what happens.
Old 01-12-2015, 06:57 PM   #7
cnk
Drives: '13 DGM BRZ Limited
Did you close your trunk completely? I killed my battery the other week when the trunk wasn't closed all the way. Charged it back up and it's been fine.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 01-12-2015, 07:02 PM   #8
evan
Drives: fr-s
Do you have jumper cables and a friendly neighbor?
Also, get yourself a multimeter. It will pay itself off hundreds of times over.
evan is offline   Reply With Quote
Old 01-12-2015, 07:05 PM   #9
swarb
with a sig of your bmw.... the frs knows you love the bmw more, so she tried taking herself out of life support. (the battery)
Old 01-12-2015, 07:31 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Probably don't need to buy a battery, jump the car and drive it for an hour to charge it up, figure out if you have a fault in the system first, even the most competent of master mechanics make mistakes.
cdrazic93 (01-12-2015)
Old 01-13-2015, 10:19 AM   #11
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Buy a multimeter while you're there!
billwot is offline   Reply With Quote
Old 01-13-2015, 10:34 AM   #12
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
H I tried hooking up spark plugs to the battery and the lights came on but then the car died again.
What the balls?
Old 01-13-2015, 12:06 PM   #13
Cvxne
Cvxne's Avatar
I bought a Diehard battery and now the car runs perfectly.
Old 01-13-2015, 12:20 PM   #14
Just an FYI! Us Northerners can have the horrible experience of a battery freezing if it goes flat when really cold. So replacement of a dead flat battery in below zero temperatures is just a fact of life.
Correct that he needs to check it out even though a new battery "fixed" it. Something caused it to go flat and recently installed tails is some pretty convincing evidence even if just plug and play!
strat61caster (01-13-2015)
car won't start
Tap Turn thorlius Electronics | Audio | NAV | Infotainment 304 09-29-2016 03:21 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 02:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
