Old 01-09-2015, 04:50 PM   #1
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
FFD Motorsport EVO2 Wheels
Stumbled upon them via social media, thought Id give them a share. First time I've ever heard of them, but after some quick research they seem to have their fair share in the racing scene. I've already inquired, and I was told that a design for 5x100 is in the works! Seems like a good option for a strong/lightweight wheel. Here's to hoping it'll be available on our platform soon.
Was told that the current spec below will run around $1200 USD. Not bad for 18x10 and ~20 lb?
Taken from the thread on NASIOC: http://forums.nasioc.com/forums/show....php?t=2687984
The EVOLUTION:2 stands for everything bigger and better than our first wheel, named the EVO1. The highlights of the EVO2 are:
- High wheel stiffness
- Wide Fitment - 18x10 size geared for wide rubber for motorsports use
- Lightweight – Target weight 20.5lbs
- Big brake kit and OEM brake fitment and clearance
- Proprietary Bead-Lock technology
- Flow Formed construction
- JWL/VIA Tested
Bead-Lock Technology
The Bead-Lock technology provides a means of keeping the bead of the tire seated firmly on the wheel. The serrated edge provides a mechanical friction advantage by biting into the rubber on the tire bead. In the past racers would resort to WD-40 or use of special tire lubes to reduce the chance of tire slippage, whereas the Bead-Lock technology provides a solution to the problem with no change to a regular tire mounting procedure.
Big brake kit guys should take note! EVO2s will clear the Stoptech ST60R BBK (Trophy Kit)
When we designed the kit, we took many brake considerations into account to help with a variety of brake fitments (OEM and aftermarket) the result? A generous amount of clearance and the concave spoke design that you see.
Of course design is one thing, verification is another and I'm happy to show the proof of concept
Some of you may recognize the brakes from Arthur's car in the photos (Build thread here: Alcoolaid's Build thread.
He runs the LIC flares in the rear give plenty of clearance for the 10" width. Usually Arthur runs at 12mm spacer in the rear (18x10 +35 wheels), but since our demo tires are only 255's and generally this car sees much more tire, we put on a 24mm spacer for the purpose of demonstration.
I thought this might be something cool to post. There are a few videos floating around displaying how flow formed wheels are made, but its always cooler when it's your own video
** Make sure you hit the HD button
Flow Form Manufacturing
The EVO2s are constructed through a flow forming process (also known as roll rim forging) where a rough casting is work shaped into the wheel barrel. When the wheel is spun and formed into the barrel shape, the grain structure that is created by the forming process adds strength to the barrel of the wheel. When the grain structure of the barrel is aligned it retains a higher strength than when it is random such as through older manufacturing methods such as gravity or low pressure castings. The advantage of using a hybrid process to form the wheel shape is that we can keep manufacturing costs low while keeping the high strength advantages of the forming process.
Since the grain structure of metals is not a common topic, perhaps an example of something more common such as carbon fiber can be used as an example of grain structures. The weave pattern in carbon fiber materials essentially uses the same principles as the fibers have strength in tension and so the fibers are overlapped to take advantage of the strength in multiple directions.
Most customers think of minimum weight when selecting a wheel. While this is true to a certain extent, a property that is often overlooked is the wheel stiffness. What I mean by this is that to a certain point, a wheel will flex and bend. Some wheels due to their nature of design will bend when going over large potholes or jumping kerbs on track for instance. These wheels are classified as having low stiffness, and while are usually very lightweight the trade-off is that they will tend to bend much more thus reducing driver feedback and response. Our wheels have a very high stiffness due to the spoke design and the flow formed construction providing great feedback and a robust wheel at a reasonable weight.
Joe-G is offline   Reply With Quote
Old 01-09-2015, 11:46 PM   #2
Vten
Drives: Too heavy
Subscribed .
Vten is offline   Reply With Quote
Old 01-10-2015, 01:20 AM   #3
qwerty66
Drives: frs
Would you guys prefer 17x9 or 18x10/18x9?
I want to make a interest list to get the ball rolling for the 5x100 batch
qwerty66 is offline   Reply With Quote
Old 01-10-2015, 01:25 AM   #4
Vten
Drives: Too heavy
17x9 or 9.5 , need to clear the sti brembo for me .
Old 01-10-2015, 01:42 AM   #5
Stumpygt86
Drives: Toyota GT86. N/A for life
16x8 is what I am after
Stumpygt86 is offline   Reply With Quote
Old 01-10-2015, 08:25 AM   #6
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
18x9.5 et 40
mkivalex is offline   Reply With Quote
Old 01-10-2015, 11:15 AM   #7
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
The Graphite and Satin Black look delicious! I wouldn't mind them in 17x9 or 18x8.5
JonAvalon is offline   Reply With Quote
Old 01-10-2015, 12:38 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Same here... ET+35 to +40 would be perfect. Those would look super-chunky with a 245 tire.
venturaII is offline   Reply With Quote
Old 01-10-2015, 04:13 PM   #9
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Me as well.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-10-2015, 04:14 PM   #10
BRZZZZZZZZZZ
Car Nut
Also Joe if you make those 18X10s fit on your FRS your a mad man and I want to see it next summer at auto x lol.
Old 01-10-2015, 11:40 PM   #11
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Haha still on the hunt for a nice set of used 17x8/9 wheels. Never really fan of the whole hella flush thing lol... 18x9.5 in a reasonable offset is the most Id ever run.
If you know anyone selling any Volks in that size, let me know!
Old 01-12-2015, 12:26 PM   #12
Vten
Drives: Too heavy
Any update for the 5x100 crowds , joe ?
Old 01-12-2015, 02:01 PM   #13
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
+1 for 16x8!
Old 01-18-2015, 01:42 AM   #14
Vten
Drives: Too heavy
Group buy for the 5x114.3 , 18x10 et32 ,20.5lbs is already started....$250 off the Msrp.
They can do the 5x100s , but need at least 10ppl committed ..... I got these info from nasioc.
Let's do it guys ... I'm in .
TWS Motorsport T66-F 17x9 +40 Touge Factory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-29-2014 10:19 PM
NEO Motorsport Big Brake Kit NEO Motorsport Brakes, Suspension, Chassis 2 09-23-2014 04:56 PM
No Limit Motorsport LeeMaster User/Vendor/Sponsor Reviews, Feedback, Comments 6 05-17-2013 12:16 AM
Motorsport - Bathurst coyote Other Vehicles & General Automotive Discussions 0 10-06-2012 08:11 PM
LUCK Motorsport 86 ZetaVI Scion FR-S / Toyota 86 GT86 General Forum 18 04-04-2012 02:38 PM
