Old 01-09-2015, 01:22 PM   #1
nonicname returns
Drives: 4 wheels
FA20 to FA20T conversion
This might've been discussed in the forum before but i cannot find it.
How hard would it be to upgrade the FA20 with wrx engine internals
And add an after market turbo?
Except for the turbo kit everything would be OEM.
That would yield low end torque curve i want from the wrx.
How many parts would need to be replaced?
I'm thinking pistons, rods, cams?
What else?
nonicname returns is offline   Reply With Quote
Old 01-09-2015, 03:44 PM   #2
350matt
Drives: toyota mr2/ Toyota GT86
I'd be surprised if the piston was different, I suspect the rod is the only mechanical change, a more robust and slightly shorter part to drop the compression
350matt is offline   Reply With Quote
Old 01-09-2015, 06:15 PM   #3
nonicname returns
Drives: 4 wheels
Interesting, i've never thought about that but
It would make sense i guess.
I cant believe this subject is nowhere to be found.
I want the torque i'll never get out of the
Current compression.
Old 01-09-2015, 06:35 PM   #4
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I think its because the aftermarket would probably be a cheaper solution and better suited to a person's wants.
-Jack Burton
Old 01-09-2015, 07:13 PM   #5
nonicname returns
Drives: 4 wheels
Fair comment. I'm willing to pay a little extra
Knowing OEM parts are in my engine which have
Been tested to some thorough standards.
The Following User Says Thank You to nonicname returns For This Useful Post:
tahdizzle (01-09-2015)
Old 01-09-2015, 07:35 PM   #6
Dipstik-sportech
Dipstik-sportech's Avatar
Just call up subaru and price out a short block from the fa20dit. The pistons are most likely different due to the different injection setup as direct injection relies on the crown shape for fuel mixing.
Old 01-10-2015, 10:36 AM   #7
Basket Case
Drives: 2013 Raven fr-s
I think you are underestimating the strength of factory internals...
Basket Case is offline   Reply With Quote
Old 01-10-2015, 10:42 AM   #8
rusty959
Drives: DGM BRZ limited
If you swap out internals at all, you will be losing some of the reliability that is typically perceived in an engine built by subaru.
If all you are wanting is the low end torque, just get a smaller turbo. The factory wrx turbo runs out of steam pretty quickly at high rpm's, which is the trade off for making boost so early. The fa20dit engine with a "Aftermarket turbo" will no longer have the same torque curve as the factory engine unless you get one with similar specs as the factory one..
I know you are talking about swapping out internals instead of the entire engine, but this thread may still help if you haven't seen it: http://www.ft86club.com/forums/showthread.php?t=69032
rusty959 is offline   Reply With Quote
Old 01-10-2015, 11:46 AM   #9
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
http://www.ft86club.com/forums/showthread.php?t=79549
Build Thread: Breaking-Bad SWP Build
OFFICIAL NM.FT86CLUB Facebook Page
mwjcyber is offline   Reply With Quote
Old 01-10-2015, 11:54 AM   #10
mwjcyber
mwjcyber's Avatar
FA20DIT BRZ @ STOHL RACING
BEST HID Conversion Kit out there?? VADER Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2017 07:50 AM
FA20T swap from the new subaru forester direct bolt in? DriftEightSix Engine Swaps 77 12-23-2014 07:53 PM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
E85 conversion ender2664 Engine, Exhaust, Transmission 6 09-15-2013 10:58 PM
conversion fa20 head with fb25T block ft86-UAE Engine, Exhaust, Transmission 3 06-18-2012 10:46 AM
