Old 09-15-2013, 03:56 PM   #1
ender2664
Drives: 2013 Scion FRS
E85 conversion
I searched under E85 and to my suprise nothing shows up.
What do I need to do to run E85. If there are no E85 stations around me do I have anyother options?
ender2664 is offline   Reply With Quote
Old 09-15-2013, 04:10 PM   #2
Opposed
Drives: 2013 Asphalt FR-S
Not sure how search didn't pull anything up. Go to google and type in E85 ft86club, there are countless threads on this.
You need:
1: an E85 station available
2: an E85 tune done with Ecutek (like I use) or the new ECU tuning software like BRZedit and Openflash.
There are a couple of vendors that seel off the shelf E85 tunes like fa20club, Visconti, and MotoEast...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 09-15-2013, 04:36 PM   #3
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
You'll def need an E85 station near you, and a E85 flex fuel kit. Just use google search as it seems like this search bar never works.
Old 09-15-2013, 07:50 PM   #4
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
For flex fuel , Orange wire black stripe on GD1 harness,just under passenger kick panel gets fed with 5v output of Ethanol content analyzer white blue stripe that gets its readings from sensor's green wire, you get sensor from Your tuner or zeitronix and a tune your ecutek vendor can sell you.
To run e85 with no flex setup simply flash and fill!
448hpsti is offline   Reply With Quote
Old 09-15-2013, 08:29 PM   #5
mad_sb
"E85" is too short of a search term using the site's search feature. Please go to google and enter "E85 site:www.ft86club.com/forums" the topic has been covered many times.
Old 09-15-2013, 08:40 PM   #6
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
You don't really 'need' a flex fuel kit...
CircuitJerk is offline   Reply With Quote
Old 09-15-2013, 10:58 PM   #7
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
http://www.ft86club.com/forums/showthread.php?t=44316
LeeMaster is offline   Reply With Quote
BEST HID Conversion Kit out there?? VADER Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2017 07:50 AM
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
5x114 hub conversion FRSGIRL❤ Brakes, Suspension, Chassis 1 07-06-2013 02:24 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
