Old 01-01-2015, 06:30 PM   #1
joe2628
Drives: 2014 BRZ Limited, 04 Porsche 996GT3
Exhaust Bolt Torques
Does anyone have a list of all the torques of the bolts for each piece of the exhaust?
joe2628 is offline   Reply With Quote
Old 01-04-2015, 01:22 AM   #2
humfrz
I don't ...... but you may find this useful ......
http://www.ft86club.com/forums/showthread.php?t=8121
humfrz
Old 01-04-2015, 05:58 AM   #3
kodyo
Drives: Scion FR-S
I did 22 ft-lbf for header bolts and as tight as possible without stripping for the other bolts in the system since getting a torque wrench on there wasn't very reasonable.
If you need specifics, find the service manual that's floating around on here and search that. I'd do it for you but it's a 5000 page doc, so I'd rather not.
kodyo is offline   Reply With Quote
Old 01-04-2015, 09:38 PM   #4
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
For my headers manufacterer reccomended 50 ft/lbs so i did that. For the rest components i did a dab of antisieze on the bolts then nice and tight.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 01-04-2015, 10:16 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
From the pdf service manual:
Tightening torque (Exhaust manifold sub-assembly):
30 N·m (3.1 kgf-m, 22.1 ft-lb)
Tightening torque (Exhaust pipe sub-assembly FR):
35 N·m (3.6 kgf-m, 25.8 ft-lb)
Tightening torque (Exhaust pipe assembly CTR):
18 N·m (1.8 kgf-m, 13.3 ft-lb)
Tightening torque (Exhaust pipe assembly FR):
42.5 N·m (4.3 kgf-m, 31.3 ft-lb)
Tightening torque (Bolts securing bracket of exhaust pipe assembly FR):
50 N·m (5.1 kgf-m, 36.9 ft-lb)
Gunman is offline   Reply With Quote
The Following 3 Users Say Thank You to Gunman For This Useful Post:
brybot (06-06-2019), kodyo (01-04-2015), wowy (01-05-2015)
Old 01-05-2015, 04:23 PM   #6
joe2628
thanks all, I appreciate it
Old 05-29-2017, 08:21 PM   #7
D-rek07
I"ve been doing my research but can not find what I'm looking for. Can someone explain to me what the above torques mean? I'm mainly looking for the muffler bolt torques.
D-rek07 is offline   Reply With Quote
Old 05-29-2017, 08:38 PM   #8
navanodd
Drives: 2013 BRZ Sport-tech WRB
That isn't a particularly critical torque, biggest thing to be wary of is not overtightening and snapping the bolt.
I'd recommend looking here and using the "Low carbon steel" values:
http://www.engineersedge.com/torque_table_sae_ftlbs.htm
navanodd is offline   Reply With Quote
Old 05-29-2017, 09:52 PM   #9
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
http://www.ft86club.com/forums/showthread.php?t=85760
vintagemxer is offline   Reply With Quote
Old 05-29-2017, 11:54 PM   #10
humfrz
Bubba says that if a lock washer is involved, just tighten the bolt/nut down till the lock washer is flat ..... then tighten a little bit more.
If no lock washers are involved, just tighten it good-n-snug and then tighten it a little bit more.
humfrz for Bubba
Old 05-30-2017, 10:16 AM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
I've always subscribed to the "tighten it till it strips, then back off a quarter turn" approach.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-30-2017, 02:41 PM   #12
humfrz
You must be related to my friend Bubba .......
humfrz
Stock exhaust bolt/nut sizes? l0aded Engine, Exhaust, Transmission 8 08-03-2015 06:09 PM
WTB: Rota Torques ZaneRL9 Wheels and Tires 0 11-01-2014 02:20 PM
Rota torques Chen Wheels and Tires 3 01-06-2014 04:26 AM
Need help with exhaust bolt J-Money Engine, Exhaust, Transmission 1 08-12-2013 11:11 AM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 12:48 AM
