Old 12-30-2014, 02:03 PM   #1
FRiSson
Drives: FR-S MT
Snap, crackle, pop over 70mph
Over 70 mph, I get this popping noise from the rear like a flapping piece of stiff plastic. Anyone have this, or better yet, find a fix?
FRiSson is offline   Reply With Quote
Old 12-30-2014, 02:52 PM   #2
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
I'd check all of the wheel well liners, and bumper connections.
Had an issue similar to this with my CT200h, one of the plastic bits under the car was just loose.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 12-30-2014, 04:51 PM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
Is it coming from the exterior or interior?
I know there was a TSB about a rear interior deck rattle/pop in the 2013 cars...
Old 12-30-2014, 04:58 PM   #4
Koa
Here you go bro, including a google keyword search so you can replicate how I search for things. I type whatever keywords I believe relevant, followed by, "site:ft86club.com"
https://www.google.com/search?q=rear...oe=&gws_rd=ssl
the most promising one:
http://www.ft86club.com/forums/showthread.php?t=14159
the not so promising one:
http://www.ft86club.com/forums/showthread.php?t=44636
The TSB:
http://www.ft86club.com/forums/showthread.php?t=22131
The guy who fixed his rattle even after both TSBs failed him, YMMV:
http://www.ft86club.com/forums/showthread.php?t=42065
Misc:
http://www.ft86club.com/forums/showthread.php?t=13451
just trynna teach a man how to fish!
Old 12-30-2014, 07:53 PM   #5
BRZnut
Drives: BRZ DGM Limited
the plastic around the wheel wells and the panels under the car have too much play. I noticed this during 70 mph trips to Myrtle Beach. What I did was caulk the plastic around the wheel wells and then spayed them with under coating. Also, stop the movement of the under panels with, yes, clear caulk (others have added washers to keep the under panels from moving). The plastic flutter sound that I was hearing at 70mph is now gone.
Old 01-01-2015, 12:27 PM   #6
FRiSson
Drives: FR-S MT
Thanks BRZnut. So did you unsnap the connectors and run a thread of caulk along the edge? What type of caulk did you use (Home Depot sells dozens of different types)? What did the undercoating do? - keep the panels from flexing?
Old 01-02-2015, 07:44 PM   #7
BRZnut
Did not unsnap the connectors. Just ran clear caulk along the edge of the plastic wheel wells connecting it the metal lip that curves into the wheel area. Also, ran it on top of the plastic where ever different plastic panels would meet. ...Then just used the under coating inside the wheel wells, mainly to stiffen up the plastic and to reduce the sound from the wheel wells.
The panels under the car where "connected" with caulk to keep them from moving , but did not spray under coating.
I always use this clear caulk from my projects:
http://www.homedepot.com/p/DAP-Alex-...8072/100024624
It is latex based so it is not sticky, can be smoothed easily, can be painted, and cleans up with water (pure silicone caulks are a mess to use plus they are not paintable)
Old 02-12-2015, 10:30 PM   #8
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Thanks for the info on what you did to fix it. I'm getting VERY tired of the noise.
Old 02-13-2015, 08:29 PM   #9
BRZnut
let me know if it works for you!
Old 02-13-2015, 10:19 PM   #10
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Going to be cold as balls this weekend, I doubt I'll be able to do anything about it. Oddly, I only have the noise from the right rear wheel well. Everything else is perfectly quiet.
Old 03-24-2015, 09:45 PM   #11
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
So I ended up doing something similar to this... I stuck some felt pieces I cut out of a sheet onto the inner fender everywhere the fender liner touched it. That solved 95% of my noise, so I also ran some felt between the top and bottom pieces of the fender liner. No more f'ing rattles!
Old 03-25-2015, 07:59 AM   #12
BRZnut
Glad it worked!
Old 03-25-2015, 08:16 AM   #13
All plastic where the felt is? Wouldn't want to hold moisture against any steel sections.
Old 03-25-2015, 08:59 AM   #14
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Nope, which is why I stuck the felt to the inside of the fender and not the fender liner. If I stuck it to the fender liner the felt would surely trap dirt and rub through the thin crappy paint on the inside of the fender.
Cat or axle back with the most snap, crackle and pop? tawheed Engine, Exhaust, Transmission 4 08-20-2014 02:55 AM
Stock speakers wearing out already? Crackle and pop! A few questions as well... dem00n Electronics | Audio | NAV | Infotainment 2 04-13-2013 01:53 PM
hit a pothole doing 70mph dori. BRZ First-Gen (2012+) — General Topics 22 03-22-2013 10:46 PM
Exhaust crackle and pop? Kiwi Engine, Exhaust, Transmission 19 03-22-2013 03:14 PM
Chirp at 70mph markitect Issues | Warranty | Recalls / TSB 15 12-05-2012 08:30 PM
