Senior Addict
Drives: 86 GT
How to remove alternator pulley?
As per the title, I need advice on how best to remove the alternator pulley. Thanks.
Drives: 2014 BRZ Limited SWP
Impact 24mm.
Leave the belt on. Impact off. replace. Belt back. Impact on = Profit. Should take like 15 min tops |
| The Following User Says Thank You to Kuri For This Useful Post: | Fizz (12-30-2014) |
Drives: 86
#4 | |
Senior Addict
Drives: 86 GT
Yes it is...I might get a new alternator pulley next to see whether that helps. If that doesn't work then I'll look into replacing the factory idler pulleys with either Raceseng pulleys or just OEM ones. |
| The Following User Says Thank You to Fizz For This Useful Post: | TemeCal (12-30-2014) |
Senior Addict
Drives: 86 GT
By the way I was looking at the Nuline website and they have Overrunning Alternator Pulleys.
Is it suitable for use on our alternator, and what's the pros/cons of such pulleys versus standard type pulleys? |
There's been reports of the idlers wearing out sooner for Raceseng. Anyone hear about the redesign or replacements?
Drives: 2013 BRZ Limited
Overdrive pulleys would typically be used if you have an underdrive pulley for the crankshaft. I would not recommend them for use alone as you can create problems with the alternator.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
| The Following User Says Thank You to CoupedUpSubie For This Useful Post: | Fizz (12-30-2014) |
| Alternator pulley removal | ShadowSeraph | Engine, Exhaust, Transmission | 5 | 04-15-2017 11:56 PM |
| Perrin crank pulley / Beatrush alternator pulley | Krimlin | Engine, Exhaust, Bolt-Ons | 7 | 08-26-2013 10:12 AM |
| WTB Tomioka Alternator Pulley | Anthony | Want-To-Buy Requests | 0 | 07-31-2013 11:21 PM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 07:45 PM |
| Alternator pulley?? | xpicer | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-13-2012 08:54 AM |
