Old 04-16-2013, 04:49 PM   #1
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Alternator pulley removal
I have purchased the Go Fast Bits alternator + water pump pulley to go with my Perrin crank pulley. I am having trouble getting the alternator pulley off. If anyone that has done this can share a proper method and tool to remove said pulley, it would be excellent.
BTW mine is an automatic if it matters
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 04-16-2013, 05:07 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Use an impact gun.
JDKane527 is offline   Reply With Quote
Old 04-16-2013, 05:40 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
I've had to use a screw driver through the cooling fan fins to hold the stater inplace. I haven't done the job with this alternator though so YMMV.
I'll second the impact aswell.
Old 04-16-2013, 06:42 PM   #4
JDKane527
JDKane527's Avatar
I tried inserting something inside the alternator body to hold the shaft, and rotate the nut with a breaker bar. I was scared of breaking a fin or messing something up, so I went to a shop where they had the right tool for the job.
I have messed things up in the past trying to do things with the wrong tool. Doing it with the right tool will save you time, money, and the headaches of fucking shit up haha.
Old 04-15-2017, 08:42 PM   #5
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I know this post is years old but I just want to add this for anyone who might be installing an alternator pulley bolt in the future. Do NOT use a screw driver through the cooling fan fins in the back to hold it in place. I tried to do this while changing out my pulley tonight, and now I have one broken alternator which lucky me is just cosmetic damage. Take the time to get a strap wrench to hold it in place while you torque the bolt. (I used google while working on the car to find this post, figured I would give it a try. Lesson learned.)
Trueweltall is offline   Reply With Quote
Old 04-15-2017, 11:56 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Alternator disassembly
Alternator Options AtlasMick Electronics | Audio | NAV | Infotainment 19 08-18-2021 03:02 PM
Alternator pulley torque setting?? ahaghshenas Engine, Exhaust, Transmission 4 07-27-2014 08:03 PM
Greddy 86 Oil cap, HKS air filter, Beatrush Alternator Pulley alrashwa Engine, Exhaust, Bolt-Ons 10 03-21-2013 11:37 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
Alternator pulley?? xpicer Scion FR-S / Toyota 86 GT86 General Forum 2 10-13-2012 08:54 AM
