Old 12-29-2014, 08:04 PM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
How to remove alternator pulley?
As per the title, I need advice on how best to remove the alternator pulley. Thanks.
Fizz is offline   Reply With Quote
Old 12-30-2014, 11:10 AM   #2
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Impact 24mm.
Leave the belt on. Impact off. replace. Belt back. Impact on = Profit.
Should take like 15 min tops
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
Fizz (12-30-2014)
Old 12-30-2014, 11:32 AM   #3
TemeCal
Drives: 86
Does this have anything to do with the squeaking in the Innovate thread? If so, please keep us posted if it resolves the issue!
TemeCal is offline   Reply With Quote
Old 12-30-2014, 11:53 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes it is...I might get a new alternator pulley next to see whether that helps. If that doesn't work then I'll look into replacing the factory idler pulleys with either Raceseng pulleys or just OEM ones.
The Following User Says Thank You to Fizz For This Useful Post:
TemeCal (12-30-2014)
Old 12-30-2014, 12:15 PM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
By the way I was looking at the Nuline website and they have Overrunning Alternator Pulleys.
Is it suitable for use on our alternator, and what's the pros/cons of such pulleys versus standard type pulleys?
Old 12-30-2014, 12:32 PM   #6
Kuri
Kuri's Avatar
There's been reports of the idlers wearing out sooner for Raceseng. Anyone hear about the redesign or replacements?
Old 12-30-2014, 04:51 PM   #7
CoupedUpSubie
Drives: 2013 BRZ Limited
Overdrive pulleys would typically be used if you have an underdrive pulley for the crankshaft. I would not recommend them for use alone as you can create problems with the alternator.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Fizz (12-30-2014)
Alternator pulley removal ShadowSeraph Engine, Exhaust, Transmission 5 04-15-2017 11:56 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
WTB Tomioka Alternator Pulley Anthony Want-To-Buy Requests 0 07-31-2013 11:21 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
Alternator pulley?? xpicer Scion FR-S / Toyota 86 GT86 General Forum 2 10-13-2012 08:54 AM
