Old 12-27-2014, 04:55 PM   #1
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
CEL P0301, P0351, and P0172
Have these lovely codes on my turbo-ed FR-S. I'm curious if anyone boosted has gotten these codes and what was the remedy since every thread I look at discussing these codes doesn't discuss the results or solutions.
Edit: Coil pack #1 has already been replaced and the car began misfiring and the code came back again.
Darryljr11 is offline   Reply With Quote
Old 12-27-2014, 05:23 PM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
I've heard of P0301 and P0351 being attributed to coil pack failure often, and is usually fixed with the replacement of the coil pack. P0172 I got too while doing some tune testing, it gets triggered running rich and is related to the tune more than likely. I was testing with the entire open loop table set to 12 AFR and richer to look at my SD volumetric efficiency table accuracy and I had that code pop up eventually.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
The Following User Says Thank You to zkv476 For This Useful Post:
Darryljr11 (12-27-2014)
Old 12-27-2014, 06:20 PM   #3
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Mmm if coil was replaced and you still got the code... DI Seal
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 12-27-2014, 07:43 PM   #4
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
I thought id hear the popping noise people said they hear when the seal is bad but car sounds fine. I will be getting all the plugs and injectors pulled next week.
Old 01-18-2015, 11:55 AM   #5
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
So spark plugs replaced, all injector seals were replaced but they weren't damaged, port injectors cleaned and flow tested. Motor is still good according to leak down test, coil packs replaced and car is alot less knock sensitive now. However there is another problem. This problem may actually be the reason the car has had its other issues. Apparently My AVCS system is malfunctioning. It is only working some of the time. I never threw any codes for 36,xxx miles to know this was an issue and Ptuning discovered it this past week when they dynoed the car. Apparently there is a TSB for this issue that corresponds with my VIN and P0301 code so that will be the next thing looked into this week.
Old 02-02-2015, 11:01 PM   #6
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
So wanted to give an update. So far my issues have resolved. Turns out my camshaft position sensors were out of specification and needed to be shimmed. This is why the AVCS system was not working or only working some of the time and the car was misfiring and driving in limp mode (around 240whp). After performing the TSB for the issue the car was run on the dyno over 20 times and road tested and made the amount of power it should and no longer pulled timing. I want to thank PTuning for performing the work that fixed the issue with my car. Just FYI I felt my car misfiring long before I got a code for the issue so if your early production FRS/BRZ/86 is misfiring this may be the issue for you.
The Following 3 Users Say Thank You to Darryljr11 For This Useful Post:
Efferalgan (06-07-2015), RavioliG (09-03-2017), strat61caster (02-03-2015)
Old 02-03-2015, 01:28 AM   #7
86Tony
Drives: 2015 AOZORA EDITION
Good to hear everything is running back to normal. This is good for someone that will run into this problem in the future. I will save this for my notes in case I ever run into this.
86Tony is offline   Reply With Quote
Old 02-03-2015, 02:37 AM   #8
acro
Drives: GT-86
What Vin numbers are affected
acro is offline   Reply With Quote
Old 02-03-2015, 10:28 AM   #9
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I have that information at work. I will post the affected VIN in a few hours.
Muaddib is offline   Reply With Quote
The Following User Says Thank You to Muaddib For This Useful Post:
Darryljr11 (02-03-2015)
Old 02-03-2015, 01:21 PM   #10
Muaddib
Mentat
Muaddib's Avatar
PRODUCTION CHANGE INFORMATION:
This TSB applies to vehicles produced BEFORE the Production Change Effective VINs shown below.
MODEL PRODUCTION CHANGE EFFECTIVE VIN
FR-S JF1ZNAA1#D#721474
Old 02-03-2015, 07:39 PM   #11
FirestormFRS
What size shims and where can you buy em?
FirestormFRS is offline   Reply With Quote
Old 02-04-2015, 12:11 AM   #12
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
You have to buy the shim kit even though you will probably only use one shim from each kit. You'll need one for each sensor and there are four. Not every car will need the same size shims.
Old 02-04-2015, 12:38 AM   #13
Muaddib
Mentat
Muaddib's Avatar
You can buy individual shim but the kit would be a better choice.
Old 02-14-2015, 02:43 PM   #14
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
I have another unfortunate update. The tsb no longer appears to have fixed the problem. The car felt down on power this morning so i decided to log the power output. Car is only making about 210whp and 212wtq like before which means the avcs is not working (not advancing timing). Car will be back at Ptuning this coming week. If qnyone knows any toyota or subaru employees who can offer insight into this issue it would be much appreciated.
Code P0351 Trouble shooting? Bahraini86 Issues | Warranty | Recalls / TSB 46 09-10-2017 05:07 PM
Major accident/Engine failure after repeated P0351/P0017/P0019 DB86 Issues | Warranty | Recalls / TSB 48 09-16-2014 04:05 PM
CEL P0301 came up today Sportsguy83 Issues | Warranty | Recalls / TSB 22 01-09-2014 01:49 PM
Spark plug replacement and P0301 errors Jacques Blom AFRICA 1 12-23-2013 05:04 PM
CEL P0301 C1201 and U0100 peachch Issues | Warranty | Recalls / TSB 32 12-21-2013 05:37 PM
