Old 12-27-2014, 10:56 AM   #1
agile30
Drives: SWP Brz
OFT refuses to connect to ecu. Need help.
I purchased my oft back in february of this year and have been using it no issues. I flashed back to stage 1 in early october with no issues. So i put the oft away at home.
Fast forward to two days ago. I go to flash a different tune on the car and it doesnt register the "key on." So i unplugged it and tried again a few times. Same thing. It throws an error saying that it cant connect to the ecu. I then tried to see if the datastream would work but it says that it cant connect to the ecu as well.
Anyone have info on what to do?
agile30 is offline   Reply With Quote
Old 12-27-2014, 10:58 AM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Probably a wiring issue with your obd2 header. Check that no pins have popped out on the back
- AdrianG
AdrianG is offline   Reply With Quote
Old 12-27-2014, 11:12 AM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
- AdrianG
That would be my guess as well. In order to power up the OFT (or any device with OBD2 plug connectivity, only the 12v power and GND pin needs to make contact. But in order to actually communication with the ECU, the CAN high and CAN low pins need to make contact as well. My guess is that one of these pins is either pushed out of the plug, bend or perhaps the female contact is rounded out. A quick visual inspection should determine things.
Old 12-27-2014, 11:27 AM   #4
agile30
Drives: SWP Brz
Sweet. Ill go check that out. Thank you for the quick response.
Old 12-27-2014, 11:46 AM   #5
agile30
Drives: SWP Brz
Aaaaaaaand you guys are awesome. Thank you sirs.
The Following User Says Thank You to agile30 For This Useful Post:
Shiv@Openflash (12-27-2014)
cars.com editor refuses to buy FR-S because of scion badge 86868686 FR-S / BRZ vs.... 121 09-16-2014 02:40 PM
Subaru refuses to work on FR-S Rabble Issues | Warranty | Recalls / TSB 28 08-31-2013 03:41 AM
How to connect this headunit? Amir Ghadiri Electronics | Audio | NAV | Infotainment 8 07-23-2013 11:57 AM
Is it possible to connect subwoofer? Ronin_car_lover Electronics | Audio | NAV | Infotainment 4 08-01-2012 10:10 PM
