Old 12-23-2014, 02:04 AM   #1
xDanger_208x
xDanger_208x's Avatar
Drives:
P3 gauge/wideband integration??
My question is..
Is the P3 pulling it's afr from the front O2?
I'm wondering if you could use a wide range O2 in the rear location and view it on the gauge somehow.
Sorry if this isn't the proper section. I just figured nobody outside the FI section will have much interest in this topic.
xDanger_208x is offline   Reply With Quote
Old 12-23-2014, 02:23 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The P3 has 2 analogue inputs so yes you could wire a wideband to it if it has a 0-5v or similar output.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-23-2014, 03:27 AM   #3
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by xDanger_208x View Post
My question is..
Yes you can, P3 have instructions on their website how to set it up. Any UEGO that has an analog 0-5v output will work.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 12-23-2014, 11:12 AM   #4
kbogarto
Drives: 2013 BRZ limited WRB
I replaced my second O2 sensor with a wideband(innovate LC-2) and wired it directly into the ECU.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 12-23-2014, 11:50 AM   #5
xDanger_208x
Drives:
I'm debating if I should just do a wideband gauge on its own, or the p3 with wideband wired in.
The p3 is "neat" but I think it's a gizmo for lack of a better term.
Old 12-23-2014, 07:12 PM   #6
sam69
Drives: GT 86
I'm doing a wideband on it's own with extra bung welded in before the cat.
sam69 is offline   Reply With Quote
Old 12-23-2014, 08:45 PM   #7
normancw
normancw's Avatar
Drives: 128i
I also have a P3 and I bought an Innovate LC-2, but I haven't installed it yet. Do you have any instructions? Did you follow a DIY?
normancw is offline   Reply With Quote
The Following User Says Thank You to normancw For This Useful Post:
xDanger_208x (12-23-2014)
Old 12-27-2014, 09:57 AM   #8
kbogarto
I ran the Wiring from the O2 through the firewall just behind the glovebox. Then I used the cigarette lighter behind the glovebox for my power and ground sources. Then you only have one wire you have to wire into the ECU which is also right there behind the glovebox. I'll try and find the link to the thread showing which wire to replace running into the ECU. It was a blue wire with white stripe.
The Following User Says Thank You to kbogarto For This Useful Post:
normancw (12-27-2014)
Old 12-27-2014, 10:00 AM   #9
kbogarto
Here is the picture showing where to wire in the O2 into the ECU
http://www.ft86club.com/forums/showthread.php?t=57902
AEM Wideband Failsafe Gauge Pitman Forced Induction 51 08-14-2016 11:06 AM
WTB: wideband sensor/gauge SterlingBrz Want-To-Buy Requests 0 09-13-2014 11:54 AM
FA20CLUB Ultimate FR-S/BRZ Gauge Integration FA20Club.com Forced Induction 401 11-15-2013 11:40 AM
FA20CLUB FR-S/BRZ Gauge Integration- Install other sensors question mtimney Electronics | Audio | NAV | Infotainment 2 07-24-2013 03:27 PM
AEM Failsafe wideband gauge. skatery1989 Interior Parts (Incl. Lighting) 2 04-14-2013 09:12 AM
