Old 06-29-2013, 02:32 PM   #1
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
FA20CLUB FR-S/BRZ Gauge Integration- Install other sensors question
I just put in this gauge. (You can learn more about it -- http://www.ft86club.com/forums/showthread.php?t=36788 )
It works great, but would like to hook up a PropSport oil pressure sensor to it. But, I'm in need of help with the wiring...and p3Cars doesn't have its install guide up yet and what they do have is rather limited in info.
I have the ProSport harness...which ends with a 4-pin clip with three wires connected to it (red, white & black). Any thoughts on how to make this work?
Thanks!
Mark
mtimney is offline   Reply With Quote
Old 06-29-2013, 09:47 PM   #2
getbent
Drives: 2013 FR-S Blue MT
I believe it connects the the three-pin connector on the fa20club gauge cable. You will need to track down what each of those three colors are for so you can connect them properly to your oil pressure gauge. Maybe send an email or call p3cars to see if they can give you a pinout.
Thanks!
Mark
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 07-24-2013, 03:27 PM   #3
mtimney
mtimney's Avatar
Great customer service from P3cars in regard to installing another company's oil pressure sensor. I emailed P3 and within an hour I had a response on how to hook up the ProSport sensor I had to the gauge.
Red (+5v) goes to the purple wire (on the p3 harness aux plug)
Black (GROUND) goes to the black wire (on the p3 harness aux plug)
White (SIGNAL) goes to Analog IN 1 (brown on gauge harness)
Nice to see a company take care of its customers!
The Following 3 Users Say Thank You to mtimney For This Useful Post:
B T (07-29-2015), bee_are_zee (03-08-2015), nix (08-21-2013)
DIY: ATI 60mm Vent Pod Install With Defi Gauge RallySport Direct DIY (Do-It-Yourself) Guides 70 11-26-2017 11:05 PM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
FA20CLUB Ultimate FR-S/BRZ Gauge Integration FA20Club.com Forced Induction 401 11-15-2013 11:40 AM
all done driver01 Engine, Exhaust, Transmission 4 06-27-2013 06:06 AM
Trying to install FA20club CAI need some help Bg8780 Engine, Exhaust, Transmission 25 03-27-2013 08:02 PM
