Old 12-21-2014, 11:38 PM   #1
Skorov
Skorov's Avatar
Drives: 86 GTS White
Interior Lights Flickering
Hi all,
Recently, I have noticed that my interior lights started flickering slightly when at idle. I have checked the battery and the alternator. Both seem to be outputting a good voltage.
Battery: 12.7V
Alternator: 14.2V
Seems like an alternator issue, but could it already have died after just 2 years? Maybe I got a dud...
Any advise on what else I should check or how to I can confirm that it is an alternator issue?
Thanks!
Skorov is offline   Reply With Quote
Old 12-22-2014, 02:27 AM   #2
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
If its LEDs then they are probably just dying. My driver side turn signals start flickering after driving around for more then 5 minutes so I need to replace the bulb
904FRSlow is offline   Reply With Quote
Old 12-22-2014, 04:16 AM   #3
Skorov
Skorov's Avatar
Nope. It's all internal LEDs. Definitely something with the circuitry.
Old 12-22-2014, 04:21 AM   #4
904FRSlow
904FRSlow's Avatar
Either way, interior lights are like $4 so if you can't find the problem, just buy new ones
Old 12-22-2014, 05:31 PM   #5
Skorov
Skorov's Avatar
I'm talking about the backlight LEDs for the clock, HVAC and instrument cluster. I highly doubt ~20 LEDs are failing simultaneously.
Old 12-25-2014, 10:36 PM   #6
Series.Ru
Drives: '15 Series.Blue
Have you checked your emf readings? Any local cattle mutilations?
Series.Ru is offline   Reply With Quote
Old 12-28-2014, 01:55 AM   #7
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
My dome light and exterior lights do this when idling bellow 800rps :/ alternator is putting out over 14 volts and put a brand new battery in. Still the problem persists.
FRSfan111 is offline   Reply With Quote
Old 05-08-2015, 12:04 AM   #8
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Bump anyone figure this out?
The lights don't flicker when my cars off but do once on.
It's happening my my dome / visor lights
Old 05-08-2015, 12:34 AM   #9
Euro7R
Drives: 2013 Subaru BRZ
Is your lights stock or aftermarket leds? I've seen some aftermarket leds flicker due to bad quality and not related to the car itself.
Euro7R is offline   Reply With Quote
Old 05-08-2015, 12:34 AM   #10
Chimera
Drives: FRS
Flickering as a full shutoff flicker, or as in dimming intensity? I'm wondering if this could be a pwm issue with the bcu.
Either way sounds like a feature to me.. J/k however I am curious too as I have a few accessories hanging off the dome light circuit myself.
Old 05-08-2015, 11:47 AM   #11
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Its not so much a flicker as a pulse. Ill try to see if I can get it on video.
My dome is a cheaper led board but my visors have good bulbs in them and do the same. Any suggestions on where to buy the bulbs?
Old 05-08-2015, 12:12 PM   #12
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
diode dynamic makes some decent ones
Dome Light
Old 06-16-2015, 09:27 AM   #13
Inextirpable
Awesome
Inextirpable's Avatar
Drives: World Rally Blue Subaru BRZ
Was there any update to this?
I have started to noticed that my interior lights, DRL's, and brake lights will flicker/pulse when the car is under 1,000 RPM. I took it into the dealership and they said that it was not the alternator, battery or any of the grounds. They were actually unable to find the problem but said it may be the ECU, however they are expecting me to pay for that so as of this I have decided to not go down that route just yet so I am wondering if anyone has any other ideas.
Inextirpable is offline   Reply With Quote
Old 02-23-2016, 06:56 PM   #14
Burrcold
Drives: Subaru BRZ Limited
Anybody have any experience with this? I'm now getting the same thing. Dome light and factory DRL both flicker when under 1k rpm.
Wiring interior L.E.Ds to come on with the interior lights/headlights TEXAS_LE Electronics | Audio | NAV | Infotainment 2 12-13-2014 10:18 AM
Sidemarker LEDs flickering CreinCrein Cosmetic Modification (Interior/Exterior/Lighting) 5 05-12-2014 09:53 PM
HID BULB FLICKERING HELP!! ijuliusx Cosmetic Modification (Interior/Exterior/Lighting) 3 05-24-2013 04:18 AM
LED Interior lights USMC -FRS Cosmetic Modification (Interior/Exterior/Lighting) 2 12-24-2012 11:24 PM
Interior Lights xcelir8brz Cosmetic Modification (Interior/Exterior/Lighting) 18 09-05-2012 04:36 AM
