Built Not Bought
Drives: 2012 Toyota 86 ZN6
Twisted chassis?
I ran a search on this but couldn't find anything...
I've had my coilovers/wheels installed for a while now but it's only recently that I've lowered the car to where I want it after pulling the rear guards etc. I have the rears and the fronts measured to perfection (spring length at 0 preload and ride height) but I've noticed that the left rear sits low and the left front sits a little higher and the right rear is high and the right front a little low, overall there's a difference of around 10mm. Obviously I could adjust the ride heights to equal everything out but first I thought I would get some opinions on what may be causing this, twisted chassis maybe? |
Chances are much better that it's unequal weight distribution than a twisted chassis.
That said, how are you measuring ride height? It's highly unlikely that the LR and RF would be lower than the RR and LF. Bent or not, that's a very improbable way for it to ride.
#3 | |
Built Not Bought
Weight distribution in these cars is pretty good, and theres no aftermarket parts that would put it off by that much |
Señor Member
It could just be tolerances in the springs or top mounts putting things out. I highly doubt you have a twisted chassis.
Or maybe you are just making so much torque the chassis twisted coming off the line.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | lukey86 (12-21-2014) |
Drives: 2015 Series.Blue
I'd be more inclined to think a fender is out of alignment than the chassis being twisted.
| The Following User Says Thank You to Poodles For This Useful Post: | wparsons (12-21-2014) |
#6 | |
Built Not Bought
I just figured with the skin and bones style chassis these cars have coupled with the rough roads we have down here (and my driving lol) it could be a possiblitity It doesn't really matter either way, I was just probing to see if anyone has faced a similar issue before. The car still handles like a champ so I'll just make the necessary adjustments to even things out. |
Senior Addict
Drives: 86 GT
Same experience here. When I installed my Bilstein coilovers I noticed that the actual ride height was uneven between left and right (by about 8-10mm), even though the spring preloads were all matched perfectly prior to install. So I just leveled everything out on the height adjusters and have not had any issues whatsoever.
In fact, the "proper" way to adjust would have been for me to use weight scales, and in doing so would probably end up having different preloads on all 4 corners anyways. But I don't have scales and I don't really care about corner balancing. |
#8 | |
You'd probably be surprised how off the weight balance could be even with the springs measuring level in the air. What coilovers do you have? It's entirely possible there is some inconsistency with the spring rates causing this as well. The proper way to do this is to adjust until the car is level (or balanced if corner balancing), not by setting the perches to the same measurements.
Drives: Fr-s
Setting by static ride height will get you close but the car needs to be corner weighed.
If you have separate ride height and preload and you are pre setting it off the car then I'm not surprised at all that the ride heights are off. It's like getting high performance tires then never checking the air pressure. |
#10 | |
Built Not Bought
Thanks for the input |
| DFW cruise down to Twisted sisters 8/8/14 | carbonBLUE | Southwest | 79 | 06-11-2015 12:27 PM |
| New STi Chassis Mounts | Beyer Subaru | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 59 | 12-14-2014 11:08 PM |
| Twisted seat belt | Fastbrew | Issues | Warranty | Recalls / TSB | 9 | 05-12-2014 11:54 PM |
| "Twisted Sisters in the Hill Country" | zooki | Southwest | 6 | 06-23-2013 08:03 PM |
| FR-S Chassis Code | mediumbrown | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 08-01-2012 10:04 AM |
