Old 12-21-2014, 05:20 PM   #1
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
Twisted chassis?
I ran a search on this but couldn't find anything...
I've had my coilovers/wheels installed for a while now but it's only recently that I've lowered the car to where I want it after pulling the rear guards etc.
I have the rears and the fronts measured to perfection (spring length at 0 preload and ride height) but I've noticed that the left rear sits low and the left front sits a little higher and the right rear is high and the right front a little low, overall there's a difference of around 10mm.
Obviously I could adjust the ride heights to equal everything out but first I thought I would get some opinions on what may be causing this, twisted chassis maybe?
lukey86 is offline   Reply With Quote
Old 12-21-2014, 06:02 PM   #2
wparsons
wparsons's Avatar
Chances are much better that it's unequal weight distribution than a twisted chassis.
That said, how are you measuring ride height? It's highly unlikely that the LR and RF would be lower than the RR and LF. Bent or not, that's a very improbable way for it to ride.
flickr
Old 12-21-2014, 06:13 PM   #3
lukey86
Built Not Bought
lukey86's Avatar
With the car up on jack stands the RR/RL measurements are equal both by measuring hub to fender and measuring the coil dimensions as well, same story for FR/FL, but when the car sits on the ground (perfectly level concrete slab btw) the R/L sits lower than R/R by around 10mm and F/R sits lower than F/L by the same measurement
Weight distribution in these cars is pretty good, and theres no aftermarket parts that would put it off by that much
Old 12-21-2014, 07:32 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
It could just be tolerances in the springs or top mounts putting things out. I highly doubt you have a twisted chassis.
Or maybe you are just making so much torque the chassis twisted coming off the line.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
lukey86 (12-21-2014)
Old 12-21-2014, 07:36 PM   #5
Poodles
Drives: 2015 Series.Blue
I'd be more inclined to think a fender is out of alignment than the chassis being twisted.
The Following User Says Thank You to Poodles For This Useful Post:
wparsons (12-21-2014)
Old 12-21-2014, 07:45 PM   #6
lukey86
Built Not Bought
lukey86's Avatar
Front is possible maybe but rear fenders are static and its happening font and rear, plus 10mm is way too much not to be noticed at the fender gaps
I just figured with the skin and bones style chassis these cars have coupled with the rough roads we have down here (and my driving lol) it could be a possiblitity
It doesn't really matter either way, I was just probing to see if anyone has faced a similar issue before. The car still handles like a champ so I'll just make the necessary adjustments to even things out.
Old 12-21-2014, 08:40 PM   #7
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Same experience here. When I installed my Bilstein coilovers I noticed that the actual ride height was uneven between left and right (by about 8-10mm), even though the spring preloads were all matched perfectly prior to install. So I just leveled everything out on the height adjusters and have not had any issues whatsoever.
In fact, the "proper" way to adjust would have been for me to use weight scales, and in doing so would probably end up having different preloads on all 4 corners anyways. But I don't have scales and I don't really care about corner balancing.
Fizz is offline   Reply With Quote
The Following 2 Users Say Thank You to Fizz For This Useful Post:
lukey86 (12-21-2014), wparsons (12-21-2014)
Old 12-21-2014, 09:34 PM   #8
wparsons
wparsons's Avatar
Up on jack stands meaning the body resting on jackstands, or the control arms resting on jackstands?
You'd probably be surprised how off the weight balance could be even with the springs measuring level in the air.
What coilovers do you have? It's entirely possible there is some inconsistency with the spring rates causing this as well.
The proper way to do this is to adjust until the car is level (or balanced if corner balancing), not by setting the perches to the same measurements.
flickr
Old 12-21-2014, 09:36 PM   #9
redlined600
redlined600's Avatar
Drives: Fr-s
Setting by static ride height will get you close but the car needs to be corner weighed.
If you have separate ride height and preload and you are pre setting it off the car then I'm not surprised at all that the ride heights are off.
It's like getting high performance tires then never checking the air pressure.
redlined600 is offline   Reply With Quote
Old 12-21-2014, 09:43 PM   #10
lukey86
Built Not Bought
lukey86's Avatar
Sweet as, I won't be corner balancing, I'll just adjust until it sits level
Thanks for the input
DFW cruise down to Twisted sisters 8/8/14 carbonBLUE Southwest 79 06-11-2015 12:27 PM
New STi Chassis Mounts Beyer Subaru Suspension | Chassis | Brakes -- Sponsored by 949 Racing 59 12-14-2014 11:08 PM
Twisted seat belt Fastbrew Issues | Warranty | Recalls / TSB 9 05-12-2014 11:54 PM
"Twisted Sisters in the Hill Country" zooki Southwest 6 06-23-2013 08:03 PM
FR-S Chassis Code mediumbrown Scion FR-S / Toyota 86 GT86 General Forum 2 08-01-2012 10:04 AM
