Old 12-20-2014, 09:40 AM   #1
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Quietest EL Header?
I currently have a TRD cat-back and am considering adding a header to the mix, but at the same time I'm at that age where I don't want to have a loud, raspy exhaust note. So I'm looking for the quietest EQUAL LENGTH header to pair with my TRD. Include sound clips too! Bonus points for sound clips with the TRD cat-back! Thanks guys...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
SurfAndSand (01-09-2015)
Old 12-20-2014, 10:17 AM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
All un-catted EL headers are relatively equal for loudness the only differences in sound would be due to thickness of the steel used. If you are looking for catted EL header that would be quieter but there is a trade off for less power. All the rest of the mitigation of loudness and rasp is going to be achieved by resonators, secondary cats and mufflers. As a general rule if your current exhaust set up is at the loudness level you find tolerable, going to a header will be significantly louder. You should be able to find sound clips of various EL headers out there but the biggest differences in noise will be from exhaust set ups without resonators or secondary cats and muffler size. Not so much from the header itself.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
rb6freak (12-20-2014)
Old 12-20-2014, 10:37 AM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
P&L coated and Catted
With an OFT Tune
Apoc, the loss is 2 hp, at 7000, 2 hp
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
P&L Motorsports (01-22-2015)
Old 12-20-2014, 10:58 AM   #4
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
JDL EL catted header maybe? I have that one with a nameless catted & resonated front/over pipe and the stock cat back and it is very acceptable as far as volume, even on cold starts. I have no problem driving around a residential neighborhood early/late at night.
Mad_Mike is offline   Reply With Quote
Old 12-20-2014, 08:27 PM   #5
akyp
Drives: 2012 86
Installed P&L catted/coated header and overpipe. Apart from a more bassy tone it is not louder than stock at all. However, to get the most out of it you would need a tune.
akyp is offline   Reply With Quote
The Following User Says Thank You to akyp For This Useful Post:
Old 12-20-2014, 08:31 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
NEVER!
Old 12-21-2014, 10:05 AM   #7
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
I am still on the fence about ordering this exact header. I was 1 click away from getting it on a black friday sale but i was too concerned about the change in noise level.
I hate loud exhausts and especially drone and ive been researching this header for months and all the sound clips that have the P&L Catted header also have various other aftermarket exhaust parts so its hard for me to tell how it will sound in my stock exhaust system. At what RPM does it become noticeably louder? Cold start idle? What Speed? Will it be annoying loud cruising at 70-85mph?
Shinobu's Smile is offline   Reply With Quote
Old 12-21-2014, 10:30 AM   #8
akyp
Drives: 2012 86
When you go WOT there's a bit more metallic noise at 3-4k. Same kind of noise (a bit more than stock) during cold start but goes away as soon as the sequence is finished. You will not notice any difference at all when cruising.
Shinobu's Smile (12-21-2014)
Old 12-21-2014, 10:45 AM   #9
tonystewart
This setup with a cat isn't loud, different but not loud. My daughter is running a stock catback. Check my signature
It becomes louder at WOT
I lowered the cold start idle speed with OFT
It is quiet at cruise, until you give it the beans, then it sounds powerful, not loud or obnoxious
Merry Christmas
Old 12-21-2014, 01:45 PM   #10
Shinobu's Smile
: ( Now I regret not jumping on things when they had the Black Friday sale.
Thank you both for your input and the soon to be hole in my wallet.
Old 12-22-2014, 08:49 AM   #11
Silver Ignition
APEXHNTR
Merry Christmas
Any chance either of you could get some sound clips and/or decibel readings(using an app like "Decibel 10th")?
And what cat-backs do you guys have paired with this header?
(and by the way I am tuned)
Thanks!!
#1867 of 2500
Old 12-22-2014, 09:16 AM   #12
akyp
Drives: 2012 86
Thanks!!
I've tried recording a clip with my Sony Actioncam but any difference I could hear in person is drowned out by road noise in the resulting clip even with the cam inside the car. The clip sounds exactly the same as a stock car. I still have stock catback, frontpipe and sound tube.
Not sure a dB reading would be of much help either as I don't have a reading prior to installing the header, and background noise will skew the results.
Old 12-22-2014, 09:41 AM   #13
Silver Ignition
APEXHNTR
Well I have a dB reading of my car with just the TRD cat-back of 85dB at 1200rpm cold start...just wanted to see how much louder it will be
#1867 of 2500
Old 12-23-2014, 08:49 AM   #14
vgi
Drives: frs
IMO @Apoch answer is the only one meaningful unless you can find a comparison chart on nose levels (highly doubt it). The rest of these is just peops' opinion on what they think is loud which may not be what you think is acceptable. Eg for me a tsudo catback was way too loud on startup and ok once warmed up whereas many folks were saying it's one of the quietest catbacks. MXP says they use thicker SS than most (might be just marketing) so I would call the vendors and compare the thickness of SS they use for headers. On the plus side MXP price is reasonable (i had a quote from Malen from @FTEIGHTSIX) and comes with overpipe.
vgi is offline   Reply With Quote
Loudest to Quietest Exhaust System list (FRZ/BRZ) Invalid Engine, Exhaust, Transmission 163 03-16-2019 01:25 PM
quietest muffler out there eighty666 Engine, Exhaust, Transmission 35 05-20-2014 07:07 PM
what's the quietest way to flatten the torque dip? autobrz Engine, Exhaust, Transmission 35 12-20-2013 07:03 PM
Quietest Exhaust Made in USA? ngabdala Engine, Exhaust, Transmission 71 04-26-2013 11:39 AM
Lightest/quietest exhaust system out there GTB/ZR-1 Engine, Exhaust, Transmission 25 10-31-2012 12:45 AM
