Old 07-29-2013, 11:20 AM   #1
autobrz
Drives: Mazda 3
what's the quietest way to flatten the torque dip?
What's the quietest way to flatten out the torque dip?
I don't care about power gain or cost, just the torque dip?
I think the obvious answer is supercharger on stock exhaust and intake. What about n/a options?
What kind of header is quieter? 4-1 EL? 4-1 UEL? 4-2-1 EL? My previous experience on an i-4 motor is 4-2-1 long tube is a lot quieter than 4-1 shorty headers.
is it enough to get just header + overpipe + catted and resonated front pipe?
I'm wondering if a tune is necessary or the stock tune will also run with much less torque dip?
also which header is tuned more for mid-range vs top-end? I know the smaller diameter primaries tend to produce more torque and choke a little up top. There is just a lot of info and I hope to see what is the minimum I have to do to flatten out the dip some.
autobrz is offline   Reply With Quote
Old 07-29-2013, 11:28 AM   #2
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
By just replacing the stock header with my Borla UEL.. or any other header of your choosing will flatten it out quite a bit. I changed the header first with stock exhaust still there and noticed a huge difference in the dip range. After the header back exhaust change out, that torque dip was even less noticeable. Dyno Charts on this forum can back this up
Edit* Exhaust is probably the least expensive and if you get a resonated cat, decently quiet... though "quiet" is subjective to how each individual perceives audible levels.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 07-29-2013, 11:39 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
If you want to stay NA then a catted header and reflash will keep things nice and quiet and flatten out that torque curve quite a bit.
Since cost is no issue, you always could throw a supercharger on there as well. That will surely eliminate the torque dip, while staying relatively quiet and producing quite a bit of power. Robispec is running his innovate on stock exhaust I believe.
Old 07-29-2013, 11:49 AM   #4
Bullnettles
Drives: Scion FR-S 2013
OP, I've got close to the same issue you have for a quiet exhaust and power. I installed an SP Elite first, and it was almost not noticeable (wasn't, at idle). Then I did a UEL and overpipe, and the volume increased a bit, but idle was still quiet. I then did a catted front-pipe and it went from mild to wild (for my tastes). I had to remove it. I think a UEL with an overpipe, and stock from there on back, would be your best option. I have no tune.
Bullnettles is offline   Reply With Quote
Old 07-29-2013, 11:54 AM   #5
autobrz
Drives: Mazda 3
thx for the info on the front pipe is the stock one resonated?
Old 07-29-2013, 11:58 AM   #6
dabocx
dabocx's Avatar
Drives: Scion FRS
Perrins exaust is pretty quiet, you could pick up that and a catted header with a tune. Would be pretty quiet and solve your problem.
Or just throw a S/C on the car and leave everything else stock.
dabocx is offline   Reply With Quote
Old 07-29-2013, 12:06 PM   #7
jamesm
turbo. it's a muffler as well as it is a power adder
Old 07-29-2013, 12:09 PM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
If all you want is to eliminate the torque dip under acceleration, you might want to watch the thread on the electric supercharger. Ridiculously easy installation and zero need to mess with the exhaust. It is looking like it will require a tune, but nothing is perfect. It is for fun on the street and not to make your vehicle a race car, but it might be what you are looking for.
Old 07-29-2013, 12:10 PM   #9
Bullnettles
I believe so, but it's been a few weeks since I swapped them, and I have a memory of a goldfish.
Old 07-29-2013, 12:51 PM   #10
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
The stock front pipe has a small resonator at the rear and cat at the front. The sound increase in swapping is probably due to the high flow cat in the replacement. I'm running the FA20club header with cat, motiv overpipe and motiv high flow cat front pipe with stock catback and FA20club tune. I'm very happy with the sound and performance improvement. I also wanted rid of the torque dip. I want to keep things quiet as well.
FastLane1000 is offline   Reply With Quote
Old 07-29-2013, 01:23 PM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
doesn't that work only under WOT?
Old 07-29-2013, 01:42 PM   #12
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Phantoms electric supercharger. Not only flattens it but obliterates it.
Toma is offline   Reply With Quote
Old 07-29-2013, 01:57 PM   #13
mid_life_crisis
Sure, that's why I said "fun on the street" and not race car.
Old 07-29-2013, 02:22 PM   #14
Toma
Also works at low speed during some part throttle conditions.
Best fun for the buck. Just tuned another one last night 181lb ft where the torque dip was. Lol
Loudest to Quietest Exhaust System list (FRZ/BRZ) Invalid Engine, Exhaust, Transmission 163 03-16-2019 01:25 PM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 09:37 PM
Quietest Exhaust Made in USA? ngabdala Engine, Exhaust, Transmission 71 04-26-2013 11:39 AM
Lightest/quietest exhaust system out there GTB/ZR-1 Engine, Exhaust, Transmission 25 10-31-2012 12:45 AM
