| Member's Car Journals Car journals by our members. |
Project "SUBRA"
Just for some back information, I've owned 3 MKIV supras. My first I converted from NA to single turbo, the second was stock TT that I upgraded to really push the stock twins, and the third was a single turbo with upgraded fuel. All of them were so much fun for different reasons. Anyway, those cars were great but I really wanted to do something new and fresh, so I ended up buying a 2013 BRZ because it to me it honestly looked like a fresher version of the supra platform exterior wise and I had full intentions of turboing it and honestly keeping it for a long time. After contacting multiple companies, both local, and quite a distance away, I decided to bring it to PTuning in May. The goal was to maximize the output on pump gas.
Coming from the supra crowd, I was tired of running race gas, or 100 pump (if I could ever find it) just to have fun. PTuning offered a water meth injection setup to maximize the output using 93 octane taking away the stress from having to run only race gas for high boost. I was sold. Fast forward 8 months, and this is how the car stands: ![]() ![]() ![]() ![]() ![]() This is running 14 psi on 93 octane + WMI: ![]() This is running 21 psi on water meth injection: ![]() Mod list: PTUNING tuner turbo kit (GT-3076R) PTUNING fueling package PTUNING cat-back exhaust Exedy stage 2 clutch & flywheel kit Snow Performance water/meth kit AEM wideband AEM WMI failsafe monitor Small Battery kit PTUNING header Then to get a little more in depth we built the block: CP 10:1 Forged Pistons BC Forged I-Beam Rods ACL Main and Rod Bearings ARP Head Studs ARP Case Bolt Kit ARP 2000 Main/Rod Bolts There are 4 maps on the car: Map 1: 18-21psi Map 2: 18-21psi, Blip Shift Map 3: 17psi Map 4: 14psi Here is a little pull on low boost (map 4 / 14 psi). I accidentally left traction control on, which spoiled the fun at the end of second gear and caused that little delay. [ame]http://youtu.be/CSC1dTldWmg[/ame] Also on low boost (until the 4th (last) pull, it doesn't look like it in the vid, but it was going like a raped ape until traction broke and i cut it) [ame="https://www.youtube.com/watch?v=FLSoENsCodI"]http://www.youtube.com/watch?v=FLSoENsCodI[/ame] I have to say, this is one of the best cars I've ever owned. I only wish that the custom plate in massachusetts for "SUBRA" weren't taken
Drives: 2013 Raven FRS MT
Very nice! I just decided on PTuning as well. Great looking kit and quality all the way through.
You will be happy you decided with them. They're outstanding.
My FR-S has 5 gears
Drives: FRS/280z/Tundra
I entered thinking I was going to see another 2j build.
Nice though, I love the ptuning setup.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Is the rest of the car stock besides the turbo kit and built motor?
Gotta love those numbers, wow.
Clever name too! Grab a SUBRA1 or SUBRA86 license plate.
clean clean clean setup. That W/M bottle+mini batt combo though, jeeeezus.
Nutty #s as well- must be a blast |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I came in here expecting a brz with a 2jz swap. But this is just as cool if not better since you are sticking with the fa20.
Any gearbox issues at this power?
Hehe sorry for those expecting a 2JZ swap! I did want to stick with the FA-20 though
![]() Yeah, the rest of the car is still stock. Still on stock fuel pump etc... just larger injectors. The drive train / gear box seems to be handling it just fine. I believe PTuning clocked over 300 miles on the dyno with this car, which is a considerable amount so it's been holding up well. |
#10 |
Drives: 2013 Scion FRS
Nice numbers! impressive.
#11 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Awwwwwwwwwwwww!!!
#12 |
TURBOLICIOUS
Drives: a machine :]
#13 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Was expecting a 2JZ swap with overnight parts from Japan, but still nice. Post a video please.
#14 |
Drives: Supra, 2014 BRZ
Absolutely amazing! Would love to check this thing out in person sometime.
| "Type 2" project teaser. :) | Wonderbar | Cosmetic Modification (Interior/Exterior/Lighting) | 148 | 02-04-2015 11:14 PM |
| New(to me) ride. Project "Wasted Youth" | zooki | Other Vehicles & General Automotive Discussions | 0 | 07-27-2014 11:01 PM |
| BrzRacer's "Trueno" SWP Brz Project | BrzRacer | Member's Car Journals | 17 | 03-18-2013 11:39 PM |
| Project "Riced-Out Scion" | VenomRush | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 108 | 05-14-2011 07:59 AM |
