Old 12-17-2014, 10:24 PM   #1
Blizzz
Project "SUBRA"
Just for some back information, I've owned 3 MKIV supras. My first I converted from NA to single turbo, the second was stock TT that I upgraded to really push the stock twins, and the third was a single turbo with upgraded fuel. All of them were so much fun for different reasons. Anyway, those cars were great but I really wanted to do something new and fresh, so I ended up buying a 2013 BRZ because it to me it honestly looked like a fresher version of the supra platform exterior wise and I had full intentions of turboing it and honestly keeping it for a long time. After contacting multiple companies, both local, and quite a distance away, I decided to bring it to PTuning in May. The goal was to maximize the output on pump gas.
Coming from the supra crowd, I was tired of running race gas, or 100 pump (if I could ever find it) just to have fun. PTuning offered a water meth injection setup to maximize the output using 93 octane taking away the stress from having to run only race gas for high boost. I was sold.
Fast forward 8 months, and this is how the car stands:
This is running 14 psi on 93 octane + WMI:
This is running 21 psi on water meth injection:
Mod list:
PTUNING tuner turbo kit (GT-3076R)
PTUNING fueling package
PTUNING cat-back exhaust
Exedy stage 2 clutch & flywheel kit
Snow Performance water/meth kit
AEM wideband
AEM WMI failsafe monitor
Small Battery kit
PTUNING header
Then to get a little more in depth we built the block:
CP 10:1 Forged Pistons
BC Forged I-Beam Rods
ACL Main and Rod Bearings
ARP Head Studs
ARP Case Bolt Kit
ARP 2000 Main/Rod Bolts
There are 4 maps on the car:
Map 1: 18-21psi
Map 2: 18-21psi, Blip Shift
Map 3: 17psi
Map 4: 14psi
Here is a little pull on low boost (map 4 / 14 psi). I accidentally left traction control on, which spoiled the fun at the end of second gear and caused that little delay.
[ame]http://youtu.be/CSC1dTldWmg[/ame]
Also on low boost (until the 4th (last) pull, it doesn't look like it in the vid, but it was going like a raped ape until traction broke and i cut it)
[ame="https://www.youtube.com/watch?v=FLSoENsCodI"]http://www.youtube.com/watch?v=FLSoENsCodI[/ame]
I have to say, this is one of the best cars I've ever owned. I only wish that the custom plate in massachusetts for "SUBRA" weren't taken
Blizzz is offline   Reply With Quote
The Following 11 Users Say Thank You to Blizzz For This Useful Post:
AZOOZ_95 (12-18-2014), B-R-Z (12-18-2014), DavidBob (12-18-2014), hmong337 (12-18-2014), itsbirdy (01-11-2015), Jrryjms07 (12-18-2014), Koa (12-18-2014), midnight23 (01-12-2015), Mrc@ptuning (12-22-2014), Pat (12-18-2014), Patrick@Ptuning (12-19-2014)
Old 12-17-2014, 10:45 PM   #2
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Very nice! I just decided on PTuning as well. Great looking kit and quality all the way through.
AVodka14 is offline   Reply With Quote
The Following User Says Thank You to AVodka14 For This Useful Post:
Blizzz (12-17-2014)
Old 12-17-2014, 10:55 PM   #3
Blizzz
You will be happy you decided with them. They're outstanding.
The Following User Says Thank You to Blizzz For This Useful Post:
Old 12-18-2014, 09:03 AM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I entered thinking I was going to see another 2j build.
Nice though, I love the ptuning setup.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
Old 12-18-2014, 09:40 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Is the rest of the car stock besides the turbo kit and built motor?
Old 12-18-2014, 10:38 AM   #6
illest86
Gotta love those numbers, wow.
Clever name too! Grab a SUBRA1 or SUBRA86 license plate.
illest86 is offline   Reply With Quote
Old 12-18-2014, 10:57 AM   #7
Koa
clean clean clean setup. That W/M bottle+mini batt combo though, jeeeezus.
Nutty #s as well- must be a blast
Old 12-18-2014, 11:34 AM   #8
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I came in here expecting a brz with a 2jz swap. But this is just as cool if not better since you are sticking with the fa20.
Any gearbox issues at this power?
hmong337 is offline   Reply With Quote
Old 12-18-2014, 12:49 PM   #9
Blizzz
Hehe sorry for those expecting a 2JZ swap! I did want to stick with the FA-20 though
Yeah, the rest of the car is still stock. Still on stock fuel pump etc... just larger injectors.
The drive train / gear box seems to be handling it just fine. I believe PTuning clocked over 300 miles on the dyno with this car, which is a considerable amount so it's been holding up well.
Old 12-18-2014, 02:30 PM   #10
Fresh86
Fresh86's Avatar
Drives: 2013 Scion FRS
Nice numbers! impressive.
Fresh86 is offline   Reply With Quote
Old 12-18-2014, 03:37 PM   #11
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Awwwwwwwwwwwww!!!
slicktop is offline   Reply With Quote
Old 12-18-2014, 04:36 PM   #12
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Originally Posted by slicktop View Post
Awwwwwwwwwwwww!!!
x2
Drift&Drag is offline   Reply With Quote
Old 12-18-2014, 05:00 PM   #13
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Was expecting a 2JZ swap with overnight parts from Japan, but still nice. Post a video please.
B-R-Z is offline   Reply With Quote
Old 12-18-2014, 07:16 PM   #14
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Absolutely amazing! Would love to check this thing out in person sometime.
Kotu100 is offline   Reply With Quote
"Type 2" project teaser. :) Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 148 02-04-2015 11:14 PM
New(to me) ride. Project "Wasted Youth" zooki Other Vehicles & General Automotive Discussions 0 07-27-2014 11:01 PM
BrzRacer's "Trueno" SWP Brz Project BrzRacer Member's Car Journals 17 03-18-2013 11:39 PM
Project "Riced-Out Scion" VenomRush FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 108 05-14-2011 07:59 AM
