Old 12-15-2014, 03:34 PM   #1
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
stock block max HP and max RELIABLE HP?
I tried searching and didn't find anything. If there's already a topic, please let me know. I'm looking to see what the stock block can hold, both all out and reliably. Thanks
Shane
HAWAIICALIVEGAZ is offline   Reply With Quote
Old 12-15-2014, 03:44 PM   #2
Koa
Just because you have Hawai'i in your name, I'll point you to some easily googled threads
http://www.ft86club.com/forums/showthread.php?p=1416315
http://www.ft86club.com/forums/showthread.php?p=949756
http://www.ft86club.com/forums/showthread.php?p=2037907
Lots of topics around on this- not a lot of data and perspectives on these engines yet to draw any definite conclusions
Old 12-15-2014, 03:50 PM   #3
Maximum reliable hp, at a trackable level? About 380 crank, and 300 tq. Light street use? Depends on how you drive.
Old 12-16-2014, 09:07 PM   #4
jflogerzi
jflogerzi's Avatar
IMO even those numbers are not 100% accurate. Really the correct answer is no one knows for sure. Lower boost and a correct tune are keys for longevity. You gotta pay to play. So I would going into expecting to need to rebuild your engine @ some point
Old 12-16-2014, 09:27 PM   #5
Those numbers assume a great tuner is involved.
The torque number is 100% known, and the horsepower is an extrapolation of the torque.
Unless you have a lot of money lying around for an aftermarket transmission.
Old 12-16-2014, 09:35 PM   #6
HAWAIICALIVEGAZ
Thanks for the replies everyone. General consensus is roughly 300 whp.. what about stock drive train? IE. Clutch, Trans, diff and axles?
Old 12-16-2014, 09:36 PM   #7
HAWAIICALIVEGAZ
@Koa thanks btw lol you in HI?
Old 12-16-2014, 09:52 PM   #8
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Stock clutches seem to be done at around 200lbft. If you're doing FI i'd consider it a necessary supporting mod regardless of power output.
Whatabouteggs is offline   Reply With Quote
Old 12-16-2014, 11:45 PM   #9
jay1989
Drives: 2014 Subaru BRZ
What clutch would you recommend, I was thinking something from SPEC or Clutch Masters, but was unsure as to what style. With that said I am open to other manufactures as well.
jay1989 is offline   Reply With Quote
Old 12-17-2014, 01:50 AM   #10
sw20kosh
Drives: 2013 Black FR-S
Been tracking at 275 whp 210 wtq. Considering going up to 320 whp 230 wtq from now on. Probably will not go beyond that for fear of booming.
Old 12-17-2014, 01:57 AM   #11
mike the snake
ACT clutch with round organic disk is cheap, comes with lightened flywheel, and holds decent amounts of torque. No complaints from mine at 220-230 ft/lbs turque and 300 whp.
Old 12-17-2014, 04:03 AM   #12
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
ACT is fine for a stiffer clutch, CM is good but expensive.
The stock transmission is a hit or miss. The supra V160/161 is an expensive swap.
The R154 is a more cost effective form of a good trans swap.
The axles are probably the same, most notibly the CV joints would go out first before the axle snaps, right?
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 07:50 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
Your choice in injectors for staying with the stock block Cross Forced Induction 17 05-12-2014 01:59 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
