Drives: HONDA, TOYOTA
stock block max HP and max RELIABLE HP?
I tried searching and didn't find anything. If there's already a topic, please let me know. I'm looking to see what the stock block can hold, both all out and reliably. Thanks
Shane |
#2 |
Just because you have Hawai'i in your name, I'll point you to some easily googled threads
http://www.ft86club.com/forums/showthread.php?p=1416315 http://www.ft86club.com/forums/showthread.php?p=949756 http://www.ft86club.com/forums/showthread.php?p=2037907 Lots of topics around on this- not a lot of data and perspectives on these engines yet to draw any definite conclusions |
| The Following User Says Thank You to Koa For This Useful Post: | cdrazic93 (12-16-2014) |
#3 |
Maximum reliable hp, at a trackable level? About 380 crank, and 300 tq. Light street use? Depends on how you drive.
| The Following User Says Thank You to CSG Mike For This Useful Post: | Efferalgan (12-17-2014) |
#4 | |
#5 | |
The torque number is 100% known, and the horsepower is an extrapolation of the torque. Unless you have a lot of money lying around for an aftermarket transmission. |
#6 |
Thanks for the replies everyone. General consensus is roughly 300 whp.. what about stock drive train? IE. Clutch, Trans, diff and axles?
New build threadhttp://<a href="http://www.ft86club....p?t=100921</a> Kini will be deleted
#KINI86 build thread @HAWAIICALIVEGAZ ![]() |
#7 |
@Koa thanks btw lol you in HI?
#8 |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Stock clutches seem to be done at around 200lbft. If you're doing FI i'd consider it a necessary supporting mod regardless of power output.
#9 |
Drives: 2014 Subaru BRZ
What clutch would you recommend, I was thinking something from SPEC or Clutch Masters, but was unsure as to what style. With that said I am open to other manufactures as well.
#10 |
Drives: 2013 Black FR-S
Been tracking at 275 whp 210 wtq. Considering going up to 320 whp 230 wtq from now on. Probably will not go beyond that for fear of booming.
#11 |
ACT clutch with round organic disk is cheap, comes with lightened flywheel, and holds decent amounts of torque. No complaints from mine at 220-230 ft/lbs turque and 300 whp.
#12 |
Junior
Drives: a car
ACT is fine for a stiffer clutch, CM is good but expensive.
The stock transmission is a hit or miss. The supra V160/161 is an expensive swap. The R154 is a more cost effective form of a good trans swap. The axles are probably the same, most notibly the CV joints would go out first before the axle snaps, right?
| Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? | Yui-Chan | Forced Induction | 179 | 03-04-2015 07:50 PM |
| WTB: FA20 Long Block/Short Block blown/running | The Racers Line | Engine, Exhaust, Bolt-Ons | 7 | 07-29-2014 01:26 AM |
| WTB: FA20 Short Block or Blown Long Block | The Racers Line | Want-To-Buy Requests | 1 | 06-29-2014 05:21 PM |
| Your choice in injectors for staying with the stock block | Cross | Forced Induction | 17 | 05-12-2014 01:59 PM |
| WTB: short block or long block | DOTman05 | Engine, Exhaust, Bolt-Ons | 2 | 07-14-2013 06:48 AM |
