Señor Member
Misfires
On Friday my car threw a CEL. I checked for codes with my OFT and it was a P0315. Some googling told me this code relates to crank angle sensors and misfires. I have since been watching for misfires with the OFT and twice in the 3 days following the CEL has it registered a misfire. Once on cyl 1 and once on cyl 3.
How concerned should I be? I haven't looked for misfires before so I am not sure if it is normal for the ECU to register the occasional misfire.
1974 TA22 Celica
2013 86 GT |
#2 | |
should be a warantee job though aftermarket guys make them so suggests they do fail, hopefully its not teeth missing on sensor wheel ,very unlikely http://www.am-autoparts.com/Subaru/B...on-sensor.html |
#3 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
see engine pdf here it on top of engine towadgs back
https://docs.google.com/file/d/0B67a...p=docslist_api |
Senior Addict
Drives: 86 GT
Fortunately it doesn't look like an expensive part to replace, and easy enough to access. Keep us updated on this issue.
What about coil packs? I've understand they tend to fail as well? |
Señor Member
Coil pack failiers and injector seal leaks were my first concern, but the code it has thrown doesn't seem to be associated with that.
1974 TA22 Celica
2013 86 GT |
Señor Member
Another CEL last night when I was overtaking someone with the engine near redline. This time it was a P0351 code. So it looks like it is a coil issue. Off to toyota I go.
1974 TA22 Celica
2013 86 GT |
Senior Addict
Drives: 86 GT
Could you find out how much they cost at the dealership?
Señor Member
No problems. I'll report back here how the whole thing goes.
1974 TA22 Celica
2013 86 GT |
#10 |
Drives: 2013 FRS- Hot Lava
May I ask your build date and mileage? I've been tracking warranty issues for the twins. Thanks!
#11 |
Señor Member
Had my car in with Toyota today. Due to the high speed and rpm my car was doing when it popped the CEL they are "unable to legally replicate" the situation to diagnose the fault. So they have done nothing with my car.
When I get my car back today I'll check and report back to you.
1974 TA22 Celica
2013 86 GT |
| Loud misfires upon cold start | connorlug | Issues | Warranty | Recalls / TSB | 42 | 03-31-2016 04:43 PM |
