Old 12-14-2014, 08:21 PM   #1
Turdinator
Señor Member
Turdinator's Avatar
Misfires
On Friday my car threw a CEL. I checked for codes with my OFT and it was a P0315. Some googling told me this code relates to crank angle sensors and misfires. I have since been watching for misfires with the OFT and twice in the 3 days following the CEL has it registered a misfire. Once on cyl 1 and once on cyl 3.
How concerned should I be? I haven't looked for misfires before so I am not sure if it is normal for the ECU to register the occasional misfire.
1974 TA22 Celica
2013 86 GT
Old 12-14-2014, 09:25 PM   #2
steve99
Drives: FT86
if its throwing that code p0315 then it likely the crank sensor is playing up, but check the plug\ wiring . probably worth unplugging cleaning plug and socket and see if it persists
should be a warantee job though
aftermarket guys make them so suggests they do fail, hopefully its not teeth missing on sensor wheel ,very unlikely
http://www.am-autoparts.com/Subaru/B...on-sensor.html
Turdinator (12-14-2014)
Old 12-14-2014, 09:36 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
So my next question is, where is the sensor?
1974 TA22 Celica
2013 86 GT
Old 12-14-2014, 10:10 PM   #4
steve99
Drives: FT86
see engine pdf here it on top of engine towadgs back
https://docs.google.com/file/d/0B67a...p=docslist_api
Old 12-14-2014, 11:05 PM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Fortunately it doesn't look like an expensive part to replace, and easy enough to access. Keep us updated on this issue.
What about coil packs? I've understand they tend to fail as well?
Fizz is offline   Reply With Quote
Old 12-14-2014, 11:47 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Coil pack failiers and injector seal leaks were my first concern, but the code it has thrown doesn't seem to be associated with that.
1974 TA22 Celica
2013 86 GT
Old 12-16-2014, 07:00 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
Another CEL last night when I was overtaking someone with the engine near redline. This time it was a P0351 code. So it looks like it is a coil issue. Off to toyota I go.
1974 TA22 Celica
2013 86 GT
Old 12-16-2014, 07:12 PM   #8
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Could you find out how much they cost at the dealership?
Old 12-16-2014, 07:17 PM   #9
Turdinator
Señor Member
Turdinator's Avatar
No problems. I'll report back here how the whole thing goes.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Fizz (12-16-2014)
Old 12-16-2014, 10:54 PM   #10
sirsol66
Drives: 2013 FRS- Hot Lava
May I ask your build date and mileage? I've been tracking warranty issues for the twins. Thanks!
sirsol66 is offline   Reply With Quote
Old 01-08-2015, 11:19 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
Had my car in with Toyota today. Due to the high speed and rpm my car was doing when it popped the CEL they are "unable to legally replicate" the situation to diagnose the fault. So they have done nothing with my car.
When I get my car back today I'll check and report back to you.
1974 TA22 Celica
2013 86 GT
Loud misfires upon cold start connorlug Issues | Warranty | Recalls / TSB 42 03-31-2016 05:43 PM
