| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ limited
Wet engine bay?
So my battery has died on me three time in the past two months. I decided to buy a yellow top Optima since there ratings were amazing. Well, it is snowing out today but when I popped the hood open the original batter was all wet. The black plastic man under the battery was also. Should I be worried about this? I'm just worried that there gets a large enough amount of water on the battery to short it and create a cross current... If this is the case that could of been the issue with the old oem battery...
A.K.A. Starlord
Drives: 2015 Series.Blue
Lol. The engine bay isn't waterproof. Everything will be all wet. That's normal.
I know it's not water proof Haha, I just mean water and a battery don't usually mix well.
Drives: Toyota Highlander; Subaru BRZ (SWP)
I'm not an experienced car guy, but a cheap solution that comes to my mind is to take out the old battery, dry everything in the engine bay, put in a new battery....and take a 2-4 gallon freezer Ziploc bag and tape it over and around the battery. if it's sealed properly, water won't reach the connections.
Edit: Then again, it gets incredibly hot inside when the car is running. |
Drives: 13' DGM Built FBM BRZ
I sprayed down the engine bay with a cleaner and right after power washing while the car was on, then air gun dried. Nothing happens. Just cant soak it for a long while I guess.
Doesn't matter as electricity follows the path of least resistance.
In this case, it's not the water, but the connections that are the path of least resistance so it's fine. |
| FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 10 | 11-25-2014 11:38 PM |
| FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit | PrimeMotoring | NY / NJ / CT / PA | 2 | 10-23-2014 10:06 AM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
