Old 12-09-2014, 10:48 AM   #1
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
BRZ Fog Install
So I'm looking at getting some Morimoto XB LED Fog lights for my BRZ. The install requires me to swap the entire fog light housing. I've found tons of videos and guides for the FR-S but not the BRZ.
To change the fog housing on the BRZ, do I need to remove the bumper? Or can I just go through the front black shroud like on the FR-S?
If anyone can post a guide or video, it would be most appreciated.
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 12-09-2014, 11:13 AM   #2
cnk
Drives: '13 DGM BRZ Limited
Just go in through the fender well. No need to remove the bumper.
cnk is offline   Reply With Quote
Old 12-09-2014, 11:13 AM   #3
iLaw
iLaw's Avatar
I don't think I can get the the screws for the housing through there.
iLaw
Old 12-09-2014, 11:14 AM   #4
cnk
You can. I replaced mine with glass fog units last year. Takes about 15m per side.
Old 12-09-2014, 11:24 AM   #5
tobin
tobin's Avatar
Drives: '13 BRZ
http://www.ft86club.com/forums/showthread.php?t=20788
It takes about 20 minutes.
tobin is offline   Reply With Quote
Old 12-09-2014, 02:14 PM   #6
iLaw
iLaw's Avatar
Do you have a DIY? The linked pics on that thread are broken
iLaw
Old 12-09-2014, 02:41 PM   #7
cnk
You don't really need any pics. Just take out the 4 pop clips that you see in the fender well holding the inner fender liner to the bumper towards the front. Pull the liner back and everything is pretty obvious after that. Personally, I wouldn't do this until it gets warmer as those plastic pop clips can get brittle when it's cold out and break very easily. Unless you have some spares on hand. They are relatively cheap so I have a whole bag of them.
Old 12-09-2014, 02:47 PM   #8
tobin
tobin's Avatar
Drives: '13 BRZ
It's also in the owner's manual under how to change the fog bulbs. Once you are in there, you will see the two screws holding the housing. Remove them and the housing will slide right out. It is very easy.
Which mod to install first .... ?? humfrz Scion FR-S / Toyota 86 GT86 General Forum 9 11-09-2013 09:07 PM
MTX install Deadspool Electronics | Audio | NAV | Infotainment 1 06-27-2013 07:21 AM
Where to install amp in FRS? mit_peid Electronics | Audio | NAV | Infotainment 10 03-24-2013 01:01 PM
KW V3 on my car install ft86me DIY (Do-It-Yourself) Guides 0 03-12-2013 09:36 PM
Need help with HID install ortizwyld Cosmetic Modification (Interior/Exterior/Lighting) 4 02-21-2013 11:12 PM
