Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Cosmetic Modification (Interior/Exterior/Lighting)
Old 10-26-2012, 08:44 PM   #1
Opie
Drives: 2013 BRZ HPDE Car
Lightbulb A better BRZ foglight option!
Anyone that has a BRZ knows that the OEM foglights are a little disappointing. Not only do they look dull yellow compared to the HID headlights, but they also are not very bright and due to the odd bulb size (PSX24W) there aren't any easy upgrades available.
But there is a solution! Upgrade to foglights off of a 2011 Subaru Outback!
Why you ask? The 2011 Outback uses a more common H11 bulb and has the same mounting points and dimensions as the BRZ foglight, all wrapped in a stronger housing with a glass lens (instead of plastic BRZ lens).
Here is a comparison of the two foglights:
OEM BRZ Foglight - P/N: 84912FJ100
Weight: 0.24 lbs (Foglight including bulb)
Cost (MSRP): $149.95 each (does not include the bulb)
Bulb: PSX24W
Lens: Plastic
Housing: Plastic
2011 Outback Foglight - P/N: 84501AJ00A
Weight: 0.54 lbs (Foglight including bulb)
Cost (MSRP): $60.18 each (includes bulb)
Bulb: H11
Lens: Glass
Housing: Composite
What do you need to install?
2-Qty Foglights (P/N: 84501AJ00A)
2-Qty H11 Harness pigtails
4-Qty Wire Crimps
Tools: Phillips Screwdriver, wire cutters/stripper, electrical tape
Steps:
1 - Access back of foglight through wheel well, behind splash guard..
2 - Unplug fog light, remove 2 mounting screws, remove foglight.
3 - Install new fog light, secure with same two screws.
4 - Cut OEM foglight connector off. Using wire crimps, connect H11 harness. Wrap with electrical tape when finished.
5 - Plug harness into foglight.
6 - Reinstall splash guard.
7 - Done, have a drink.
Here's some pics:
Enjoy!
:happy0180:
2013 BRZ Premium 6MT - Track Car, 2018 GMC Canyon Denali - Tow Vehicle, 2018 Forester XT - Wife's Ride, 2016 Crosstrek - Daughter's Ride
Opie is offline   Reply With Quote
The Following 34 Users Say Thank You to Opie For This Useful Post:
1stGenBRZ86 (07-29-2013), 86BRZ (10-28-2012), B L U E S L A T E (11-06-2013), chanomatik (04-30-2013), cmspooner (04-08-2013), DAEMANO (12-09-2014), DaJo (05-04-2013), Deslock (11-05-2012), Fascist Fish (10-26-2012), fuddbutter (10-26-2012), johnb831 (10-27-2012), jonnyozero3 (02-15-2013), JonnyRocket (10-31-2012), JPxM0Dz (10-27-2012), Lee358 (10-28-2012), Loki2x (10-29-2012), M-17 (05-13-2013), meWant (11-10-2012), Nguyenstreak (10-02-2013), notFRS (10-27-2012), Scooby South (06-18-2013), sklimo (10-02-2013), slaxx (10-27-2012), sparks (10-26-2012), Sportsguy83 (01-29-2014), SubarooMike (10-27-2012), Superhatch (10-30-2012), Surok (12-16-2012), TheSt|G (10-27-2012), TouchMyHonda (12-14-2012), Turbowned (10-30-2012), Tyrant (11-30-2013), WRB-DZA-BRZ (10-27-2012), zoomzoomers (10-30-2012)
Old 10-26-2012, 11:58 PM   #2
Fascist Fish
Fascist Fish's Avatar
Drives: Sold: 13 SWP BRZ
Thanks!
where did you get your H11 Harness pigtails?
Fascist Fish is offline   Reply With Quote
Old 10-27-2012, 12:07 AM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Awesome find!
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-27-2012, 01:16 AM   #4
Le86
Drives: Asphalt FR-S
Looks like it was spliced? I could be wrong.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-27-2012, 01:28 AM   #5
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
Any pics of them on?
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 10-27-2012, 02:33 AM   #6
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
If you read you'll see you are required to splice h11 pigtails in.
Omar GC
Instagram: 2jzus
Old 10-27-2012, 02:37 AM   #7
OrbitalEllipses
Drives: Attitude
How's the color temperature on these lights? I'd prefer something that doesn't require cutting off the stock connectors.
Old 10-27-2012, 03:01 AM   #8
KI_ZN6
KI_ZN6's Avatar
Good find! Thanks for sharing =)
KI_ZN6 is offline   Reply With Quote
Old 10-27-2012, 06:12 AM   #9
Opie
Originally Posted by Fascist Fish View Post
Thanks!
Ordered them from Amazon...
Old 10-27-2012, 06:17 AM   #10
Opie
That's the beauty of these lights, the H11 bulbs come in several temperatures all the way up to 4200k that match toe OEM fogs almost perfectly. And the housings are sturdy enough to hold up to the heat of an HID conversion better than the flimsy OEM's.
Old 10-27-2012, 06:23 AM   #11
Opie
Not yet...this was a test fit of the light itself (if you notice one of the mounting arms is broken on the test light). Now that I know they fit all the necessary parts are on order for the complete install.
Old 10-27-2012, 08:59 AM   #12
2forme
I think I might have to do this conversion myself. The yellow OEM fog bothers me. LOL
Would love to get an H11 bulb that matches the OEM HIDs
Old 10-27-2012, 09:57 AM   #13
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
There are a lot of cars going to that fog light bulb and they are pretty terrible, i put some led's in my challenger that used it and they looked cool but didn't light up much.
If I was going to do this conversion i would use the PIAA Plasma Yellow H11 bulbs but thats just me.
JoeBoxer is offline   Reply With Quote
Old 10-27-2012, 11:16 AM   #14
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
you would think subaru would just say heyyy let's take the outback housing and use it to save money!
excellent info.
VSGTS14 is offline   Reply With Quote
The Following 2 Users Say Thank You to VSGTS14 For This Useful Post:
Jive Turkey (08-12-2013), usptwins (01-15-2013)
Search this Thread:
Advanced Search
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
Foglight replacement help Zadkiel Cosmetic Modification (Interior/Exterior/Lighting) 4 08-06-2012 11:11 AM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 12:47 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
