Drives: 2013 Turbo FR-S
So i've been having this issue for a week now and been trying my best to solve the problem , the problem is that the car won't start and if it does it idles real bad to a point where the whole car is shaking .
The Is an Engine check light and i pulled the code it was P0123 (Throttle Body/Pedal A High Input), So after ruling out some stuff i assumed the the TPS took a S***t so i went ahead an replaced the throttle body mind you this since the problem appeared the throttle body started Humming and making noise. i almost give up the next thing i can think of is that my gas pedal is out as well , if anyone had this problem before please share some info or what i can do to diagnose the problem |
in orbe terrum non visi
Drives: violent
Um...go to the dealer.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | J_kennington (12-03-2014) |
Drives: 2013 asphalt scion FRS
So...your warranty has expired? If not...why bother. Have it towed to dealer, BY the dealer. And make them fix it.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
Drives: Raven FR-S 6M
My guess based on his member info "Drives: 2013 Turbo FR-S" is that he has FI on the FR-S and no longer has warranty coverage.
“The World is Flat”
[||•]=(86)=[•||] |
#8 | |
Go to your tuner/vendor or ask in the FI section. |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Lol, don't you think the fact that you're boosted should have been mentioned in your first post? I knew there was more to your issue..
#10 |
Drives: '13 UM86
Broken. Return for a new one. Make sure to bring receipt for proof of purchase.
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
#11 |
Drives: Asphalt FR-S
Test the battery. Less than 11V output is enough to cause mayhem on these cars.
I had a customer come in with all kinds of startability issues and wouldn't hold an idle. Codes all over the place. Put a battery in it and it fired right back up and ran fine. Hell, on my own car, I was having all kinds of lagging and sputtering in stop and go traffic. Battery was only measuring about 8.5V and was causing my issues. |
#12 | |
#13 | ||||
from another thread-- http://www.ft86club.com/forums/showthread.php?t=77802
2. did you swap injectors? fuel pump? 3. change anything recently? Last edited by swarb; 12-04-2014 at 01:22 AM. |
#14 | |
1. did you tune the car yourself? No i have a friend that tunes my cars but he hasn't retuned the car yet with ecutek 2. did you swap injectors? fuel pump? i switched out the fuel pump to a DW65 but it was running fine after the pump install but now that i look at it closely i think there's something wrong with that pump i installed cuz its running real lean at idle ill put the stock pump on today and see if it fixes the problem , the code P0123 that came on kinda threw me in a different direction 3. change anything recently?[/quote] injectors still remain stock so just the pump |
| Nameless Down pipe doesnt fit? HELP | The86Ghost | Engine, Exhaust, Transmission | 7 | 05-14-2014 10:27 PM |
| my BRZ doesnt have a USB port, what should i do? | chenshuo | BRZ First-Gen (2012+) — General Topics | 35 | 03-02-2013 05:31 PM |
| Start-Up Idle Drop (VIDEO) | MidnightMonkey | Issues | Warranty | Recalls / TSB | 18 | 10-02-2012 01:54 AM |
| Maybe the FT-86 doesnt need massive power........ | TriggerTRD | Scion FR-S / Toyota 86 GT86 General Forum | 67 | 06-30-2011 11:58 PM |
