Old 12-02-2014, 05:02 PM   #1
Tboxer
Drives: 2013 Turbo FR-S
Exclamation FRS won't Start and doesnt want to idle !!!!
So i've been having this issue for a week now and been trying my best to solve the problem , the problem is that the car won't start and if it does it idles real bad to a point where the whole car is shaking .
The Is an Engine check light and i pulled the code it was P0123 (Throttle Body/Pedal A High Input), So after ruling out some stuff i assumed the the TPS took a S***t so i went ahead an replaced the throttle body mind you this since the problem appeared the throttle body started Humming and making noise.
i almost give up the next thing i can think of is that my gas pedal is out as well , if anyone had this problem before please share some info or what i can do to diagnose the problem
Tboxer is offline   Reply With Quote
Old 12-02-2014, 08:45 PM   #2
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Did anything happen prior to this issue? Mechanical over-rev, run out of oil, bad tune, etc?
B-R-Z is offline   Reply With Quote
Old 12-02-2014, 08:50 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Um...go to the dealer.
The Following User Says Thank You to Reaper For This Useful Post:
J_kennington (12-03-2014)
Old 12-03-2014, 12:42 AM   #4
Tboxer
Nothing that i can think of the car was driving fine, had no issues but start up was a little ruff wouldn't fire up from the first time
Old 12-03-2014, 08:13 AM   #5
J_kennington
Drives: 2013 asphalt scion FRS
So...your warranty has expired? If not...why bother. Have it towed to dealer, BY the dealer. And make them fix it.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 12-03-2014, 09:04 AM   #6
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
My guess based on his member info "Drives: 2013 Turbo FR-S" is that he has FI on the FR-S and no longer has warranty coverage.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 12-03-2014, 05:17 PM   #7
Tboxer
The car is a boosted frs and if it had warranty ij the first place i wouldn't have bothered with it
Old 12-03-2014, 05:49 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Whoever provided the turbo kit and/or your tuner would have a better idea than most people browsing this section, the only thing remotely close to what you're describing were the early cam position issues but you're not getting any CEL codes that agree with that issue.
Go to your tuner/vendor or ask in the FI section.
Old 12-03-2014, 06:34 PM   #9
B-R-Z
B-R-Z's Avatar
Lol, don't you think the fact that you're boosted should have been mentioned in your first post? I knew there was more to your issue..
The Following 3 Users Say Thank You to B-R-Z For This Useful Post:
hmong337 (12-04-2014), NickTC (12-03-2014), stugray (12-05-2014)
Old 12-03-2014, 06:58 PM   #10
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Broken. Return for a new one. Make sure to bring receipt for proof of purchase.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 12-03-2014, 07:10 PM   #11
fledonfoot
Drives: Asphalt FR-S
Test the battery. Less than 11V output is enough to cause mayhem on these cars.
I had a customer come in with all kinds of startability issues and wouldn't hold an idle. Codes all over the place.
Put a battery in it and it fired right back up and ran fine.
Hell, on my own car, I was having all kinds of lagging and sputtering in stop and go traffic. Battery was only measuring about 8.5V and was causing my issues.
fledonfoot is offline   Reply With Quote
Old 12-03-2014, 10:50 PM   #12
Tboxer
i'll test the battery but i highly doubt thats the case i have a jumper box on it and still does that
Old 12-03-2014, 11:46 PM   #13
swarb
from another thread-- http://www.ft86club.com/forums/showthread.php?t=77802
*snipped*
2- has anyone trying tuning Ecutek with FIC 660cc injectors on the car because for some reason tried doing that using Brzedit and just doesn't want to respond to that ?
*snipped*
1. did you tune the car yourself?
2. did you swap injectors? fuel pump?
3. change anything recently?
Old 12-04-2014, 08:23 AM   #14
Tboxer
No i have a friend that tunes my cars but he hasn't retuned the car yet with ecutek
i switched out the fuel pump to a DW65 but it was running fine after the pump install but now that i look at it closely i think there's something wrong with that pump i installed cuz its running real lean at idle ill put the stock pump on today and see if it fixes the problem , the code P0123 that came on kinda threw me in a different direction
3. change anything recently?[/quote]
injectors still remain stock so just the pump
Nameless Down pipe doesnt fit? HELP The86Ghost Engine, Exhaust, Transmission 7 05-14-2014 10:27 PM
my BRZ doesnt have a USB port, what should i do? chenshuo BRZ First-Gen (2012+) — General Topics 35 03-02-2013 05:31 PM
Start-Up Idle Drop (VIDEO) MidnightMonkey Issues | Warranty | Recalls / TSB 18 10-02-2012 01:54 AM
Maybe the FT-86 doesnt need massive power........ TriggerTRD Scion FR-S / Toyota 86 GT86 General Forum 67 06-30-2011 11:58 PM
