Old 12-01-2014, 04:28 PM   #1
VakaGT
VakaGT's Avatar
Drives: None
UNKNOWN SMELL?? FIXED, Close Please
Grimmspeed Intake is awesome. Smell had NOTHING to do with it. Somehow I think stale water was trapped in the AC vents/wherever due to the storm that hit after I installed intake. Lysol got rid of the problem and smell never came back.
/overreacted
/close thread please!
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 12-01-2014, 04:30 PM   #2
phrosty
This is normal. Post a log if you want someone to verify, but all the behavior you describe is normal.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
VakaGT (12-01-2014)
Old 12-01-2014, 04:34 PM   #3
VakaGT
VakaGT's Avatar
Drives: None
hmm okay. then the smell has to be something else. Can installing a new intake cause something ELSE to produce a smell? and ill post a log once i get home from work
My Build Thread
Old 12-01-2014, 11:17 PM   #4
FastWhite
Drives: Subaru BRZ Limited M/T
If you went from stock to the Grimmspeed then did you cap the sound tube at the firewall?
FastWhite is offline   Reply With Quote
The Following 2 Users Say Thank You to FastWhite For This Useful Post:
phrosty (12-01-2014), VakaGT (12-02-2014)
Old 12-02-2014, 12:31 PM   #5
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Originally Posted by VakaGT View Post
So just installed the Grimmspeed Intake with the Grimmspeed OFT Tune and its amazing. I love it. Car feels great!
BUT
When I'm accelerating my AFR Drop to 13.x:1 sometimes even 11.x:1 and 12.x:1 depending on how hard im pushing the car...
and when I let my foot off the pedal and coasttt car goes to 20.x:1
It's basically only 14.7:1 when its Idling
I wouldn't have cared until I started getting a weird smell in my cabin and I dont know what it is so I started monitoring my AFR and stuff.
Is this normal?
Completely normal. Engine should run rich when at wide open throttle for a margin of safety, should idle at pretty much stoich, and when you let off the gas it should read lean as there isn't really fuel but rather a small amount of air pumping through the motor. Everything you've said is exactly how the car should operate, good stuff!
I know in the other thread you posted in I gave you a ton of stuff to check, as I was concerned you might be running rich or lean. However, THIS right here would be a good reason why you would smell anything in the cabin. Make sure you've capped off the sound tube with the supplied cap, otherwise you have an open hole form your cabin to the engine bay, and you would have TONS of new smells in the cabin.
Thanks for helping get this sorted guys while I was away, much appreciated
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
VakaGT (12-02-2014), wparsons (12-02-2014)
Old 12-02-2014, 02:17 PM   #6
wparsons
wparsons's Avatar
This is why it's a good idea to monitor and log things before and after a change so you can see what differences the new mod caused.
The AFR's don't sound wildly off at all, I'm sure it's totally fine. If you're really concerned, log the commanded AFR as well and compare that to the actual AFR and look for big gaps.
flickr
Old 12-02-2014, 02:41 PM   #7
VakaGT
VakaGT's Avatar
Drives: None
Chase
Engineering
I already had it capped before the install so i left it capped with my cap. Did i need to use the cap that came with the product?
To cap it I used the cigarette lighter cap from the glove compartments method originally.
My Build Thread
Old 12-02-2014, 02:54 PM   #8
GrimmSpeed
GrimmSpeed's Avatar
Cigarette lighter cap works just fine. I must say this truly is an odd problem, and I have no idea what could possibly be causing a smell. You could always take the intake off, and put the stock one back on to see if the smell were to disappear. Flash the stock intake stage 1 tune too.
Chase
Engineering
Old 12-02-2014, 04:01 PM   #9
VakaGT
VakaGT's Avatar
Drives: None
Chase
Engineering
I might try to reset the ecu first tonight. My dad suggested it as well. I also switch to a a mix of 91/100 = 93 octane last night and changed the grimmspeed tune from 91 oct to 93 oct. so might see how that all goes. My coolant level is also very low (but not under the low line) i noticed. Maybe its leaking and burning off when the engine is on?
First car issue for my first car. kind of excited to solve it a challenge appears!
My Build Thread
Old 12-02-2014, 04:11 PM   #10
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Vaka, I seemed to have noticed a smell too but figured it was running rich due to the tune. Also could be burnt torque converter from Shiv's driving and dyno work....lol
It seems to have gotten better lately though I still get a gas smell sometimes.
F1fletch is offline   Reply With Quote
Old 12-02-2014, 04:41 PM   #11
Foobar
SLO NO MO
Foobar's Avatar
What's it smell like? Burning oil? Melting plastic? Fuel? Coolant?
Old 12-03-2014, 03:48 PM   #12
VakaGT
VakaGT's Avatar
Drives: None
Yes! It smells like a mix of fuel and a hospital (like a cleaning agent)
Basically the car smells like a chemical unscented clean smell thats slightly sweet smelling. i really cant describe it. I havent driven it for two days because of the storm but will reset ECU soon
If the problem still persists im taking it to the next meet and seeing if someone can identify the smell lol
My Build Thread
Old 12-03-2014, 03:53 PM   #13
raven1231
It's the smell of POWER!!!
Old 12-03-2014, 05:20 PM   #14
phrosty
Err, even if running rich, cabin air smell should not be effected. If you've got exhaust making it into cabin, that's bad times.
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 02:55 AM
So what would you say is too Lean? Too Rich ? Opinions Pls. BC-Boy Software Tuning 27 05-29-2014 11:05 PM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-26-2013 12:42 AM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 01:53 PM
running rich/stumbling Boostedpro Issues | Warranty | Recalls / TSB 1 01-28-2013 03:19 PM
