Old 05-27-2014, 05:16 AM   #1
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
So what would you say is too Lean? Too Rich ? Opinions Pls.
This is a topic to which i hear a very wide array of awnsers,
This is all based on a WOT situation with the engine on load as a typical dyno run would be performed , for the sake of simplicity.
What do you think a desirable AFR curve should look like N/A or F-I ?
What number would start to get you worried ? N/A or F-I?
Also what is your point of view on Rich conditions, and what is .. too rich ?
It would be nice to share opinions on this subject.
BC-Boy is offline   Reply With Quote
Old 05-27-2014, 06:06 AM   #2
s2d4
s2d4's Avatar
Opinions are nice and all but experience probably trumps all.
All I know is documentation from badnoodle and tuners on this platform have basically followed this except your previous choices tuners.
@jamesm may shed more light on this.
Sent from my Galaxy Nexus using Tapatalk
Old 05-27-2014, 07:33 AM   #3
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
14.7 baby! just trolling for post counts, don't mind me.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 05-27-2014, 08:58 AM   #4
J_kennington
Drives: 2013 asphalt scion FRS
On FI under WOT(full boost) I wouldn't go any leaner than 13-1. And would tune as rich as 10 or 11. On my eclipse, I consistently tune to 11-1 AFR at wide open under full boost. It's easier for me to replace 4 spark plugs than it is a block.
On NA under WOT I think I would want to stay around 13-14. It's been awhile since I've messed with an NA though...but if memory serves right, you would get the most power the closer to stoich you are.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-27-2014, 09:40 AM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Based on my limited experience with tuning, the sweet spot for N/A AFR at WOT is between 12-12.5 to 1. The AFR from stock o2 sensors is not that accurate, so most tuning I've seen done here lately keeps a bit lower at 11.5-12 as a safety margin without any loss of power.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-27-2014, 11:13 AM   #6
jamesm
on pump gas...
NA: low 12's tailing to mid-high 11's above 6.5k or so. this is because the car is crazy knock-prone up high and you can usually make more power by richening it up a bit and keeping more timing. the rich afr's we run on these cars has nothing at all to do with an O2 sensor (the car doesn't even use the O2 sensor in open loop), it's because it buys you knock resistance, and this car is extremely knock sensitive. higher DI ratio + slightly richer than typical AFR allows you to run a lot more timing and ultimately make more power.
FI: 11.6-11.4:1, again maybe richening up a bit as you get above 6.5k... for the same reasons as above. I've found that range is a really good spot for power... still allows you to run decent timing without having to give up a bunch of power going rich. power drops off pretty hard as you get into the very low 11's or down into the 10's.
As far as what AFR is 'safe' there is no right or wrong answer. There are obvious limits: if you're running 14:1 under load NA or 13:1 under load boosted that's obviously bad... but the car can start to knock just a few tenths of a point leaner than target if it's tuned fairly aggressively. The key is just to make sure that the AFR is consistent and stays where you put it... this means minimizing fueling error to less than 2% across the board and turning off LTFT in open loop, basically. You'll never have a consistent AFR with LTFT acting in open loop and high fueling error.
Old 05-27-2014, 11:40 AM   #7
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by jamesm View Post
on pump gas...
You mean every car is different??!?
Ironsquid is offline   Reply With Quote
Old 05-27-2014, 11:42 AM   #8
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You think every car/engine is the same??!?
Old 05-27-2014, 11:43 AM   #9
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Missed sarcasm is an epidemic.
Old 05-27-2014, 11:47 AM   #10
solidONE
solidONE's Avatar
Old 05-28-2014, 01:44 AM   #11
BC-Boy
BC-Boy's Avatar
I want a thicker head gasket,
Old 05-28-2014, 09:09 AM   #12
Apoc
Apoc's Avatar
Is this to lower the compression ratio?
“The World is Flat”
[||•]=(86)=[•||]
Old 05-28-2014, 12:51 PM   #13
BC-Boy
BC-Boy's Avatar
yup
Old 05-28-2014, 02:07 PM   #14
wparsons
wparsons's Avatar
Why do you want to lower the c/r?
flickr
afr, fuel, lean, rich
lean at idle only woode Forced Induction 5 05-03-2014 04:48 PM
PO171 SYSTEM TOO LEAN BANK 1 rmdrag0n Engine, Exhaust, Transmission 23 03-02-2014 12:50 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-25-2013 11:42 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 11:36 AM
