Drives: 2013 asphalt scion FRS
winjet led wiring to factory led fog strip?
So, my question is:
I have the factory led strip fog lights. Which has the strips on ea each side, a controller located under the dash, and a switch on the dash. I recently acquired a pair of winjet head lights and was thinking I could power the boomerangs with the fogs. So they run the same sequences (full on-head light off, dim head light on). Would I need to tap the winjets before the controller or after? Do the winjets have a built in controller?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
Drives: Scion FR-S
That actually doesn't seem like a bad idea. I don't know how the winjets are wired, but I would just run the positive for the LED strip on the winjets, and tap into the positive for the led strip below it. Ground on the factory headlight connector. Should be pretty simple.
| Using factory wiring for aftermarket fog light kits | Wizardhat | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 12-05-2021 04:05 PM |
| HELP: WINJET Headlight LED strip INOP | 1SIKFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-01-2014 11:28 PM |
| Wiring a sub to the factory HU | cfusionpm | Electronics | Audio | NAV | Infotainment | 8 | 05-04-2013 09:54 PM |
| Factory head unit wiring help please. | jabbajaw99 | Electronics | Audio | NAV | Infotainment | 2 | 03-24-2013 06:09 PM |
| alarm wiring help? (using factory remote) | luv85 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-28-2012 07:59 AM |
