Old 01-19-2014, 01:10 AM   #1
1SIKFRS
DEF'SIK_J_STATUS
1SIKFRS's Avatar
Drives: 2013 FRS - 2005 WRX STI
HELP: WINJET Headlight LED strip INOP
Sup peeps,
Just received my winjet lights from phastek. They look awesome, but there is one problem... LED strip on the driver side doesn't turn on. Passenger side works fine.
DRL's on stock headlight work....
Please keep me updated.
Thanks much,
Mark
1SIKFRS is offline   Reply With Quote
Old 01-19-2014, 01:44 AM   #2
DarkCard
Drives: Asphalt Scion Frs 6MT
Is it wired up correctly? I'd double check.
Possible its defective
DarkCard is offline   Reply With Quote
Old 01-19-2014, 01:48 AM   #3
1SIKFRS
DEF'SIK_J_STATUS
1SIKFRS's Avatar
I looked at the wires, all are secured and attached.
I put my old headlight on, everything worked.
passenger winjet works with all features...
hooked up the driver winjet on the passenger side--- led strip still doesn't work
Old 01-19-2014, 01:50 AM   #4
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Maybe DOA, doesn't surprise me since they are made in China. Have them replaced.
Ny Brz is offline   Reply With Quote
Old 01-19-2014, 10:15 AM   #5
Kilos6
Drives: 2013 FR-S Whiteout MT
Might want to very lightly tug on each individual wire in the harness. When I got mine the passenger side didn't turn on at all due to one wire not actually being in all the way, but when I was looking at it one wire was in the connector just not in the actual fitting? Idk electrical terms
Kilos6 is offline   Reply With Quote
Old 01-19-2014, 11:56 AM   #6
1SIKFRS
DEF'SIK_J_STATUS
1SIKFRS's Avatar
thanks i'll check that out
Old 01-19-2014, 02:17 PM   #7
1SIKFRS
DEF'SIK_J_STATUS
1SIKFRS's Avatar
bump
Old 01-19-2014, 05:27 PM   #8
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
yeah when I put mine in, the harness wire I had popped out. Just make sure you have good solid contacts for the wires. Might be worth checking inside the housing to make sure those smaller brown wires are in tact also.
Ironsquid is offline   Reply With Quote
Old 01-19-2014, 08:45 PM   #9
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Contact Phastek and see if they'll take care of it?
kmbkk is offline   Reply With Quote
Old 05-06-2014, 08:45 AM   #10
21_nola_05
21_nola_05's Avatar
Drives: 2014 scion FR-S
Originally Posted by 1SIKFRS View Post
Sup peeps,
Thanks much,
Mark
Hey same problem drivers side drl wont work second set aswell idk if im wiring them wrong .
any results
21_nola_05 is offline   Reply With Quote
Old 09-01-2014, 11:28 PM   #11
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Hi
I'm a little late to this thread party, but my passenger side led strip wasn't working
Since I am in Canada and imported them myself from NY I decided it would be too hard to return them for exchange
I checked all the connections inside and found the red & black wires were not connected at all - connector was there ok but obviously it was never plugged in
I baked it open and connected it now they work fine
Drastic measure for sure but I solved it
Good luck with your fix/exchange/refunds
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
***Official Winjet HEADLIGHT GROUPBUY - PRICE Matching - NO WAITING SHIPS NOW 86SPEED Groupbuys 559 10-27-2016 02:42 PM
WINJET Headlight Question HATED1 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-12-2015 03:46 AM
**PHASTEK** Winjet JDM Replica Headlight and Tail Light Thread PhastekSport Exterior Parts - Lighting 62 04-22-2015 04:15 AM
** WINJET TAILLIGHTS - In stock Ships Same Day 86SPEED Groupbuys 42 04-11-2014 05:12 AM
Winjet Headlight Groupbuy JDM Style - Chrome/Black 10% OFF BLACKFRIDAY SALE! Vicious LED Groupbuys 2 11-29-2013 04:05 AM
