Old 11-25-2014, 09:44 AM   #1
kylem1853
Innovate boost gauge ?? Help
Does anyone know how add a boost gauge to see what these things are actually doing on the innovate I run the torque app with the tablet which is fine but it won't register boost past like 5.7 5.9 ish for some reason wanted to know I'd there is something to change or can I add a mechanical gauge?
kylem1853 is offline   Reply With Quote
Old 11-25-2014, 10:07 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Your OEM MAP sensor will only read up to 5.7 psi so that is the limiting factor. There are higher reading sensor options, but your tune will need to be scaled for the new MAP sensor. I would personally get a mechanical or electrical boost gauge though.
Old 11-25-2014, 01:13 PM   #3
kylem1853
How would I hook a mechanical on that setup
Old 11-25-2014, 02:07 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
I run a separate digital boost reading for my P3 gauge. Just tap the same area as where the map sensor is or there is a port on the rear but you'd need to remove the charger to get access to it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-25-2014, 03:53 PM   #5
kylem1853
I HEARD ABOUT THIS NO ONE HAS PICTURES FOR THIS DO THEY. AND YOU MEAN THE MAP SENSOR ON THE BLOWER? IS THERE A CERTAIN WIRE OR WIRES? SORRY NEW TO THIS PART OF IT
Old 11-25-2014, 07:28 PM   #6
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
CAPS IS CRUISE CONTROL FOR COOL
1/8npt brass fitting nipple thing, drill and tap the MAP plate, connect mechanical boost gauge line to it then other end to the gauge. Wire in gauge. Enjoy a fluctuating number WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Also try searching i posted this shit like 1-2 pages ago on the Innovate owners thread.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 03-07-2016, 01:06 AM   #7
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Anyone know where I can get a MAP plate with a nipple so I can run a boost gauge tube to it? The bolt on the rear of the sprintex stripped when I tried to remove it.
OR
If you don't know where to get a plate, perhaps help instruct me on how to drill a hole in one and what to do to get a nipple on it. I don't really know anything about welding or metal work so I have not idea how to do it myself if I buy a new plate.
stockysnail is offline   Reply With Quote
Boost Gauge Help Needed nlowell Forced Induction 19 09-28-2019 11:20 AM
Innovate Motorsports SCG-1 Boost Control and AFR protection gauge... Now Available! Innovate Motorsports Forced Induction 19 07-16-2014 04:24 PM
Boost gauge intall, where to cut? Sniper2606 Forced Induction 4 01-21-2014 03:05 PM
Boost gauge off at elevation gdrider77 Forced Induction 7 09-25-2013 01:32 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
