Drives: 2013 Scion FRS
Boost Gauge Help Needed
Hey all,
I need some help with my boost gauge. I installed a vacuum manifold from the brake booster line (see pic 1). I installed a 3/8" T and brought the 3/8" line into the manifold where then connected out a line to the KW bypass valve and another line to the ProSport electrical sender filter and unit. All I'm getting on my boost gauge is "-29" at idle then with any throttle it flashes to "---". I've read every post I can find to resolve. Here is what I've tried:
My car is an automatic. The brake booster line does not go to the manifold. The port on the manifold that has the brake booster line on a manual transmission car has a cap on it. Instead the brake booster line runs past the manifold and enters the engine on the passenger side (see pic 2 and 3). Why would I only be getting vacuum from this point? I'm on the correct side of the brake booster check valve right? Should I just give up on this spot and pull boost from another spot? Where would that be? Thanks all!! Pic 1 - Manifold Pic 2 - Brake Booster T Pic 3 - Brake Booster Hardline Pic 4 - Brake Booster Engine Entry
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
Drives: 93.5 supra t & prius
Car should be under vacuum at idle its normal since you have no positive pressure. Once things start spooling you will get on the positive side. Hmmm. I would think the brake booster line would be fine.
I Love custom Turbo kits
Drives: Limited BRZ
The perfect source for the vacuum manifold was the capped nipple on top of the manifold because no need to tee into brake booster.
I really have no idea why would your setup not work other than a bad gauge. I would get a barbed hose coupler to restore brake booster line and remove that T and take the boost source from the capped point on top of manifold.
Drives: 2013 asphalt scion FRS
When you say "under any throttle". Are you actually out driving the car? Or in the driveway, car in neutral, and reving?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
NASA SpecE30 Racer
My advice is remove that crappy ProSport gauge from the equation and sell it to some Subaru owner. Were you utilizing this setup prior to installing the boost gauge? Is your bypass valve working properly since it is also hooked up to your vacuum manifold? I would get a mechanical boost gauge and hook it up and see what it says. You should be in the -19 to -21 inHg area at idle. Does anyone with a ProSport gauge know what the "---" means?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
what prosport gauge are you using? i have ran theirs in multiple cars and never had a issue with them. sounds like a bad source. try what @Sportsguy83 recommended
I will try that, thanks guys. I'm running the prosport evo premium and I was testing with WOT runs on the freeway. Since the gauge shows boost when I blow into the sender I'm pretty sure the gauge is fine.
That worked! I now show proper boost on my gauge. I can confirm that on my automatic, I am getting nothing but >30 lbs of vacuum from the brake booster line. Crazy...
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Brake booster should have a check valve somewhere in the line so it's always kept under vacuum. That's probably what the issue was...
#10 |
Drives: 2014 SWP BRZ, MT
I thought the check valve was in the brake booster's inlet but I suppose if there was a check valve before the booster and you tapped after that it would hold vacuum. That's strange though. My Vortech kit uses the line coming from the brake booster as the BOV vacuum line but that would only work if it was always at manifold pressure and the check valve came after. Strange strange.
#11 |
Mr. Cranky Pants
I've never actually had to find out where that check valve is, but now that I looked back and saw that he verified that he was on the correct side of it in the OP, I can see that I'm clearly guilty, in this case, of the thing that always irritates me about online forums. Bad reading comprehension...
Carry on. |
#12 | |
Drives: 2015 CWP Limited BRZ
addictedcollectibles.r/My IG
'86 E30 (Project) 'VARIS Widebody http://www.ft86club.com/forums/showthread.php?t=103676 |
#13 |
Drives: 2014 BRZ
I just installed a prosport boost gauge on Sunday. Didn't work at first. That clear vac hose they provide is probably a 1/8 of an inch in diameter inside...completely useless besides putting a half inch of it around the nipple on the back of the gauge to be able to use a 1/4 vacuum hose that ended up allowing the gauge to get a proper feed.
#14 |
Drives: Limited BRZ
That was more than two years ago, so I THINK I was talking about the PCV connection on top of the manifold. I think I said "capped" because I had it capped with a vent to atmosphere catch can.
| boost gauge vortech help | ft86me | Forced Induction | 47 | 07-06-2015 10:50 AM |
| Boost gauge error | jamesm | Forced Induction | 7 | 02-04-2014 05:08 PM |
| Boost gauge intall, where to cut? | Sniper2606 | Forced Induction | 4 | 01-21-2014 03:05 PM |
| Boost gauge off at elevation | gdrider77 | Forced Induction | 7 | 09-25-2013 01:32 PM |
| Which boost gauge? | Bigmaxy | Forced Induction | 3 | 07-07-2013 07:11 PM |
