Old 11-25-2014, 12:12 AM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Tools for air compressor ;)
Is this the right place to post... Since it is a problem
So I want to buy an air compressor for few things
1. Dry my car
2. Power my tools
I will buy a impact wrench capable of doing 400ft-lb. Will this be enough to tighten and untighten my wheel lug nuts?
I will also buy a gun that blows air to dry my car will that work or is it dangerous.. I heard that sometimes there is internal rust and its not good for the car..
Mikeez is offline   Reply With Quote
Old 11-25-2014, 03:10 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Probably wrong section but whateverwhatever I'll answer.
400 Ft/lbs is more than enough. I forgot what this car torque specs are but it's around 80 ft/lbs. Buy a torque stick if you plan on using the air gun to tighten the lug nuts or use a torque wrench.
Most impact guns are at 150 ft/lbs.
The air gun is not useful to dry the car in big areas, it's good if you need to blow dry tight crevices or need to spray air at a certain area.
I'd use a lead blower to dry the car instead of one of those air blower guns.
N1rve
Old 11-25-2014, 04:49 AM   #3
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
89ft/lb for lug nuts.
thatfilipinoguy is offline   Reply With Quote
Old 11-25-2014, 08:40 AM   #4
Imrac
Drives: 13 SWP BRZ Prem
If you are short on space or want to be more mobile, I would suggest a cordless impact wrench and impact driver.
Dewalt makes some decent wrenches and drivers. I love my impact driver from them. It's small enough to get in some pretty tight places and has a decent amount of torque. (It can do the lugs, but I usually still break them with a bar first).
You can compliment that with an impact wrench that is capable of 400ftlb for heavier work and can easily break lugs and suspension components.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 11-25-2014, 04:06 PM   #5
thatfilipinoguy
I bought a DeWalt so I can tear apart my 1JZ, it was by far the easiest engine teardown I have ever done.
Old 11-27-2014, 06:22 AM   #6
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Air is dead for almost everything. I've converted to electric tools and couldn't be happier. I've been wrenching for 12 years.
Old 11-30-2014, 05:14 PM   #7
root
Drives: Raven FR-S
I use cordless out on the field but use air at home.
Air tools are cheaper, lighter, smaller, usually more power.
400 ft lbs should be more than enough as long as the fasteners aren't seized/rusted. BTW be very careful about tightening using impact, you really shouldn't. I'll set my gun to minimum power and pulse trigger only enough to spin the lugs on. Then I'll use torque wrench to tighten to spec.
Just to be safe you should put an inline air separator/filter on the output of compressor.
root is offline   Reply With Quote
AC compressor tweet Hanzo Issues | Warranty | Recalls / TSB 96 07-04-2020 07:19 PM
where to tap compressor housing gtx turbo kingkai23 Forced Induction 1 05-24-2014 07:12 PM
Compressor/pump noise when car is off Zardoman Issues | Warranty | Recalls / TSB 11 03-10-2014 05:06 PM
Idle dip ONLY with COMPRESSOR on #87 Issues | Warranty | Recalls / TSB 2 11-14-2012 11:12 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 07:10 AM
