Old 05-24-2014, 04:19 PM   #1
kingkai23
Drives: 13 swp limited
where to tap compressor housing gtx turbo
I was wondering where is the ideal place to tap or does it matter ..im going to run vac line str8 to the wastgate .sorry for newbie ? Just wanna make sure before i start drilling
kingkai23 is offline   Reply With Quote
Old 05-24-2014, 07:12 PM   #2
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
There is a flat spot near the outlet of the compressor housing. This is where Garrett intends for you to tap into for a consistent boost (pressure) source. Drill, tap and install a 90 degree fitting pointing down towards the wastegate
14BRZ is offline   Reply With Quote
AC compressor tweet Hanzo Issues | Warranty | Recalls / TSB 96 07-04-2020 07:19 PM
Compressor/pump noise when car is off Zardoman Issues | Warranty | Recalls / TSB 11 03-10-2014 05:06 PM
Buzzing / Compressor Sound from Gas Tank Area Spd229 Issues | Warranty | Recalls / TSB 14 12-06-2013 10:17 PM
Idle dip ONLY with COMPRESSOR on #87 Issues | Warranty | Recalls / TSB 2 11-14-2012 11:12 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 07:10 AM
