Old 11-18-2014, 02:19 PM   #1
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Help with tire size please (rpf1's and DD)
Hi guys,
I need some help with deciding on the right tire size for my application/s. My car is a daily driver first and foremost, with some aggressive 'canyon carving' and spirited driving on the weekends. I also plan on eventually making it to the road course near me this coming summer for some track days.
Anyway, I will be running Enkei RPF1's in 17x9 +35, and will be setting the car on some RS*R SuperDowns for now. I'm stuck between 245/40's and 235/40's. I know the 245's are closest to the factory overall diameter, with the 235's being slight shorter (and this may not be a bad thing.) I feel that 245's are a bit much for an NA setup, granted, I am stage 2, on e85, but still. I think 235's will be better fitted for my setup.
Whats the general consensuses?
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 11-18-2014, 02:41 PM   #2
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I have 245/40 rs3s on my track wheels (17x9 rpf1), which I drive around town in occasionally because I'm lazy about swapping back. I do not feel like they are overkill for na (i've got filter, header, front/over pipe, and tune) and would gladly dd on them if I could afford to replace the rubber that often.
Mad_Mike is offline   Reply With Quote
Old 11-18-2014, 02:46 PM   #3
edeekeos
edeekeos's Avatar
Thanks! I figured the offset of weight from the RPF1's might negate any sluggish feeling due to a heavier, more 'contacting' tire, but I wasn't sure. I am not worried about retaining the 'slidey' feel of the car. Honestly, I would prefer it not to slide unless provoked. I plan on going FI anyway, actually, it was go FI now, or wheels/tires. I would rather have more grip before I go FI .
Old 11-18-2014, 03:17 PM   #4
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
I would go with 245's. Yes they are heavier but by going 235 you are essentially making the final drive ratio larger. Thus you will need to shift at lower speeds and your acceleration will hurt.
ToyoburuBRZ is offline   Reply With Quote
The rite tire size? rpf1 17x9 +45 Gillams Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 04-22-2015 12:37 PM
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 12:03 AM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 02:40 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
