Drives: 2015 Scion FRS RS 1.0
oft e85 question?
I am thinking about getting the oft and running e85 on my new 2015 FRS. it currently has 3000 miles. Should i wait till certain mileage or it doesnt matter? and I am wondering if any users have any problems running e85 long term. Also what about maintenance on e85, oil change still at 7500/miles or it have to be sooner.
Drives: JAWS
Change the oil sooner than 7500, e85 contaminates your oil more than normal fuel..also some people recommend running an e85 specific oil, I believe there's an entire thread about it. You should be good to run it at your mileage. Make sure you follow the procedure for filling up/flashing the e85 tune, which I believe is under @steve99 's OFT tips and tricks. Watch your LT fuel trims, I think they should be under 4% or so.
Whether or not you decide to run e85, you should pick up an OFT. It's awesome. |
#3 | |
as per above post read links below all should be in their
Drives: Scion FR-S 10 Series
FWIW I flashed my new FR-S at 3000 miles to E85 and actually had the first scheduled maintenance at the dealer and the stock 0-20 synthetic oil is E85 compatible.
Dealer had no idea car had been converted either |
Be prepared to watch your gas mileage fall like a rock. You will have to much fun on corn juice.
Drives: Sonic Blue 2014 GT86
Is it still advised to run a tank of 98 every 4th tank or so to keep the injectors from fouling or can you just run indefinitely with increased oils changes?
♥カレー大好き !!
Drives: ♿
hi, anyone know if gc is compatible with e85?
[ame="http://www.amazon.com/Castrol-06244-0W-30-Synthetic-Motor/dp/B007G7PUMS"]Amazon.com: Castrol 06244 EDGE 0W-30 SPT Full Synthetic Motor Oil - 1 Quart Bottle, (Pack of 6): Automotive[/ame]
#8 | |
brz\86 requires SN or GF-5 rated oil that stuff is only SL rated socits no good for car or e85. SN , GF-5 rated oils are also E85 compatable buy good oil its not worth saving a few dollars.
#9 | |
brz\86 requires SN or GF-5 rated oil that stuff is only SL rated socits no good for car or e85. SN , GF-5 rated oils are also E85 compatable see link below http://www.pqiamerica.com/apiserviceclass.htm buy good oil its not worth saving a few dollars.
#10 |
♥カレー大好き !!
Drives: ♿
thanks for the info... what would you recommend? i started running e85 @ ~7,000mi. on my odo, and i just hit 9,000... planning to do an oil change @ 10,000, which would be in a month or so...
#11 |
As per vehicle spec use a SN GF5 rated oil of correct viscosity 0W20 or if you in a hot climate 5W30 ie high temps like +30 C regularly and never see below about +5 C .
#12 |
I went with your suggestion on the nulon, the engine loves it. Thanks again steve.
#13 |
♥カレー大好き !!
Drives: ♿
alright i will go with the castrol edge... 0w-20
#14 |
Drives: Toyota GT86 6M/T
I'm thrilled to try E85 myself in a couple of weeks. Hope the cold starts won't be a problem as I live in Scandinavia. But as E85 is quite a regular fuel in Sweden, where it can get really cold, I think it isn't going to be a problem.
Can you just clarify the following for me? Running premium gas on E85 map would be damaging I presume. But running E85 on a normal gas stage 1 map shouldn't hurt the engine, right? I know that the ECU will take longer to adapt, but it will do so in the end, when there's only gas left in the tank after the next fill up. I'm not planning on doing this though, it's just nice to know in case of emergency.
| KW V3 Question | jsc1234 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-25-2014 09:16 PM |
| Question for the the 2014 Brz Nav Owners (BT Question) | jbsali | Electronics | Audio | NAV | Infotainment | 3 | 07-16-2014 11:41 AM |
| A/C question | radroach | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-13-2014 05:17 PM |
| Oft question | cooldandani | Software Tuning | 3 | 04-05-2014 11:17 PM |
| BEspoke question and rattle question | bdanisi | Electronics | Audio | NAV | Infotainment | 2 | 01-30-2013 02:11 PM |
