Old 11-17-2014, 11:04 PM   #1
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
oft e85 question?
I am thinking about getting the oft and running e85 on my new 2015 FRS. it currently has 3000 miles. Should i wait till certain mileage or it doesnt matter? and I am wondering if any users have any problems running e85 long term. Also what about maintenance on e85, oil change still at 7500/miles or it have to be sooner.
Mr_YUzU_FRS is offline   Reply With Quote
Old 11-18-2014, 12:52 AM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Change the oil sooner than 7500, e85 contaminates your oil more than normal fuel..also some people recommend running an e85 specific oil, I believe there's an entire thread about it. You should be good to run it at your mileage. Make sure you follow the procedure for filling up/flashing the e85 tune, which I believe is under @steve99 's OFT tips and tricks. Watch your LT fuel trims, I think they should be under 4% or so.
Whether or not you decide to run e85, you should pick up an OFT. It's awesome.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
diodelphi (11-18-2014)
Old 11-18-2014, 01:08 AM   #3
steve99
Drives: FT86
as per above post
read links below all should be in their
The Following 2 Users Say Thank You to steve99 For This Useful Post:
diodelphi (11-18-2014), JB86'd (11-18-2014)
Old 11-22-2014, 04:35 PM   #4
poptopclk
Drives: Scion FR-S 10 Series
FWIW I flashed my new FR-S at 3000 miles to E85 and actually had the first scheduled maintenance at the dealer and the stock 0-20 synthetic oil is E85 compatible.
Dealer had no idea car had been converted either
poptopclk is offline   Reply With Quote
Old 11-26-2014, 06:48 PM   #5
jflogerzi
jflogerzi's Avatar
Be prepared to watch your gas mileage fall like a rock. You will have to much fun on corn juice.
Old 12-02-2014, 11:42 PM   #6
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
Is it still advised to run a tank of 98 every 4th tank or so to keep the injectors from fouling or can you just run indefinitely with increased oils changes?
tmichel is offline   Reply With Quote
Old 12-03-2014, 03:07 AM   #7
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
hi, anyone know if gc is compatible with e85?
[ame="http://www.amazon.com/Castrol-06244-0W-30-Synthetic-Motor/dp/B007G7PUMS"]Amazon.com: Castrol 06244 EDGE 0W-30 SPT Full Synthetic Motor Oil - 1 Quart Bottle, (Pack of 6): Automotive[/ame]
zAnSh1n is offline   Reply With Quote
Old 12-03-2014, 03:20 AM   #8
steve99
Drives: FT86
Originally Posted by zAnSh1n View Post
brz\86 requires SN or GF-5 rated oil that stuff is only SL rated socits no good for car or e85.
SN , GF-5 rated oils are also E85 compatable
buy good oil its not worth saving a few dollars.
zAnSh1n (12-03-2014)
Old 12-03-2014, 03:22 AM   #9
steve99
Drives: FT86
see link below
http://www.pqiamerica.com/apiserviceclass.htm
Old 12-03-2014, 03:27 AM   #10
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
thanks for the info... what would you recommend? i started running e85 @ ~7,000mi. on my odo, and i just hit 9,000... planning to do an oil change @ 10,000, which would be in a month or so...
Old 12-03-2014, 03:55 AM   #11
steve99
Drives: FT86
As per vehicle spec use a SN GF5 rated oil of correct viscosity 0W20 or if you in a hot climate 5W30 ie high temps like +30 C regularly and never see below about +5 C .
Old 12-03-2014, 05:00 AM   #12
s2d4
s2d4's Avatar
I went with your suggestion on the nulon, the engine loves it. Thanks again steve.
The Following User Says Thank You to s2d4 For This Useful Post:
steve99 (12-03-2014)
Old 12-03-2014, 01:52 PM   #13
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
alright i will go with the castrol edge... 0w-20
Old 12-12-2014, 08:15 AM   #14
cawith
Drives: Toyota GT86 6M/T
I'm thrilled to try E85 myself in a couple of weeks. Hope the cold starts won't be a problem as I live in Scandinavia. But as E85 is quite a regular fuel in Sweden, where it can get really cold, I think it isn't going to be a problem.
Can you just clarify the following for me? Running premium gas on E85 map would be damaging I presume. But running E85 on a normal gas stage 1 map shouldn't hurt the engine, right? I know that the ECU will take longer to adapt, but it will do so in the end, when there's only gas left in the tank after the next fill up. I'm not planning on doing this though, it's just nice to know in case of emergency.
cawith is offline   Reply With Quote
KW V3 Question jsc1234 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-25-2014 10:16 PM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
A/C question radroach Scion FR-S / Toyota 86 GT86 General Forum 6 06-13-2014 06:17 PM
Oft question cooldandani Software Tuning 3 04-06-2014 12:17 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
