Northwest AK, ID, OR, WA
Old 11-15-2014, 05:04 PM   #1
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Thanks Decay107
Big thanks to Doug for the help on the installation of the GrimmSpeed intake
just a little blood spilled for the insall Gods
Jmonty is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmonty For This Useful Post:
DarrenDriven (11-26-2014), thehapaone (11-15-2014)
Old 11-15-2014, 06:33 PM   #2
evan
Drives: fr-s
Blood = +10hp at 7400rpm ��
evan is offline   Reply With Quote
Old 11-15-2014, 08:37 PM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
No problem, you notice a difference? I felt a little more power up top, but had it back off before my ECU could finish learning.
and @even my blood doesn't boost top end power, it gives +25wtq at 3700 RPM
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
evan (11-15-2014)
Old 11-17-2014, 03:06 PM   #4
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Do you guys know if they fixed it so it would work in conjunction with the Perrin oil cooler? I remember they were having trouble getting it in there with the sandwich plate and hoses coming out of it.
stockysnail is offline   Reply With Quote
Old 11-17-2014, 03:20 PM   #5
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
doesn't work well with it helped Doug install his and it was rubbing
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 11-17-2014, 04:00 PM   #6
Decay107
Decay107's Avatar
No.
At first I thought it might work
http://www.ft86club.com/forums/showp...2&postcount=15
But had some rubbing and took it off for now
http://www.ft86club.com/forums/showp...4&postcount=21
I can only imagine how bad the rubbing would be under track conditions.
Old 11-17-2014, 07:05 PM   #7
stockysnail
Just the tip
So much for me switching to this intake then. I think I'm nearing 2 years with the Perrin and haven't changed/cleaned the foam filter yet. Taking the front bumper off isn't a fun thing to do.
Old 11-17-2014, 07:48 PM   #8
Decay107
Decay107's Avatar
Yeah I was pretty sad to see it, looks like the only options for those who want to run an oil cooler (mocal based) are the stock box and Perrin.
On a related note, turns out I've been melting the stock intake resonator for a while now with the nameless header...
Old 11-26-2014, 05:51 PM   #9
johan
Drives: '14 981CS, '99 NB1
You don't have to take off the front bumper....
johan is offline   Reply With Quote
Old 11-26-2014, 05:55 PM   #10
johan
http://www.ft86club.com/forums/showt...08#post1967508
Old 11-26-2014, 08:20 PM   #11
stockysnail
Just the tip
I meant I need to remove the bumper with my Perrin intake. I know I don't with the grimmspeed.
Old 11-27-2014, 11:53 AM   #12
johan
Check the link I posted above. I posted how to get into that area behind the bumper without taking the bumper off.
