Old 11-14-2014, 05:12 PM   #1
Toxicmilk45
Toxicmilk45's Avatar
Drives: White out FRS
Part Shop Max X Whiteline Endlink Rub
So I have the Part Shop Max Pro coils and whiteline endlinks up front with stock sway bar. I was adjusting my height when I noticed the marks on the endlink.
Here is a picture of it at full lock:
I'm thinking that if I add more negative camber or remove the washer from the endlink part that connects to the sway bar and adding that washer to the one that connects to the coilover it will fix the rubbing but I haven't tried it yet.
Does anyone know why this might be happening? Like endlink length maybe?
The coils are maxed low with all the collars still and I'm not really that low so I don't think that would be the problem
Toxicmilk45 is offline   Reply With Quote
Old 11-15-2014, 04:04 PM   #2
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
The thing thing i see is that your links are set to full short. I think you should shorten the link by the same amount you have dropped. I have my end links 1" shorter than oem and work just fine. Try increase their length by 1/2". These things move in weird ways and the length may have a big impact on the way they articulate.
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Toxicmilk45 (11-15-2014)
Old 11-15-2014, 06:45 PM   #3
Toxicmilk45
Pretty helpful photo, what kind of coilovers do you have?
I'm going to try and extend the endlinks tomorrow and Ill let you know the results. What is your ride height like compared to mine?
Old 11-16-2014, 08:44 AM   #4
yomny
yomny's Avatar
Im running ST coilovers, and i'm dropped about 1.5" across, probably less than you since you mentioned you were all the way down. Best of luck, let me know how it goes.
Old 11-16-2014, 09:12 AM   #5
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
yup this is also the current topic in the drifting thread...
http://www.ft86club.com/forums/showt...31#post2024131
but dont worry, your buddies at Powered by MAX seem to have a solution!
i would actually like to see what happens when we put a GoPro in there to watch all this binding mayhem. might help figure things out.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
The Following User Says Thank You to Shinchu For This Useful Post:
Toxicmilk45 (11-16-2014)
Old 11-16-2014, 02:26 PM   #6
yomny
yomny's Avatar
So you're saying they bind because of the coilovers? Is what i picked up from that link you posted.
Old 11-16-2014, 09:46 PM   #7
Toxicmilk45
Wow I read about how salva removed his seat bars but I didn't know that it had to do with this. I guess I'm just going to take off my endlinks and sway bars for now. Thanks for you help guys
Old 11-16-2014, 10:53 PM   #8
Shinchu
Shinchu's Avatar
im saying they bind because its a dumb design. honda put the ilnks on the strut like this with the 2012+ civics too. i dont know why they dont just link to the lower arms like they have on billions of other cars.
starting to think i will just weld a stud on my sock arms and call it a day.
Old 11-17-2014, 08:30 AM   #9
yomny
yomny's Avatar
That'll work ,this way we dont have to be getting different length endlinks..
Old 11-17-2014, 09:43 AM   #10
Toxicmilk45
Will it be worth welding the stud? Apparently it may handle better without the sway bar so I think I'm going to keep mine off and drive with it for a while
Old 11-17-2014, 01:57 PM   #11
yomny
yomny's Avatar
I drove without it for a day and the car didn't seem to have that much roll, It actually had a smoother less resisting steering feel to me.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
Old 11-18-2014, 02:47 AM   #12
Shinchu
Shinchu's Avatar
you guys would seriously rather drive without it all together instead of fixing the problem?
thats like saying "oh my vision was getting blurry so instead of getting glasses i just had my eyeballs removed."
Old 11-20-2014, 03:57 AM   #13
Knshro13
Drives: 10 series FRS
The car will almost always drive better with sway bars. The issue comes when you start drifting it. It drifts better without the factory endlinks attached. It's a dumb design that causes the links to bind resulting in poor self steer and response.
With normal driving (or rather, stuck driving) it's better with sway bars attached. With drifting, it's better without it, unless you have modified the LCA to attach the end links.
Knshro13 is offline   Reply With Quote
Old 11-28-2014, 07:39 AM   #14
Shinchu
Shinchu's Avatar
Powered by Max or Parts Shop Max is working on lower arms that relocate the links to the arm instead of the strut. just like i had in mind...
PA: Part out 57xtreme 18x9.5 +40/Coilovers/LCAs/Perrin 2.5"/Whiteline tapsumbongfrs Wheels and Tires 7 11-09-2014 11:46 AM
Front swaybar endlink problem CyberAkuma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-28-2014 09:15 PM
NJ - Parts FS - Mirror/FrontPipe/Exhaust/Endlink pjpetrozelli NY / NJ / CT / PA 4 11-15-2013 03:40 PM
*PHASTEK* Whiteline Buy One Get One Free Endlink Promotion PhastekSport Brakes, Suspension, Chassis 0 08-16-2013 10:37 AM
Aftermarket endlink advantages Kai Uhl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-03-2013 07:22 PM
