Old 11-14-2014, 01:17 PM   #1
wootwoot
Drives: FRS
Wheel for 300zx brake swap
I am sure most of you have seen the 300zx brake swap for the FRS/BRZ. If not, here it is:
http://www.nicoclub.com/archives/nis...r-frs-brz.html
They are 30mm calipers and 317mm front rotors. I was wondering if you could fit them under 17" wheels. I know the stock rims won't work. I was hoping to run a 17x7.5 with a 42mm offset but have no clue what will work. Any advice would be appreciated.
wootwoot is offline   Reply With Quote
Old 11-14-2014, 02:42 PM   #2
wootwoot
Drives: FRS
Just learned that the stock wheels fit the brake kit with an 8mm spacer. Given stock offset, what offset will clear the brakes?
Also, the 300ZX came with 17" wheels so this should be possible.
Old 11-14-2014, 03:30 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Brake caliper clearance is dictated by spoke design more so than offset.
-alex
Old 11-14-2014, 03:40 PM   #4
wootwoot
Drives: FRS
So then something flat or concave will give me the best chances of clearing?
Old 11-14-2014, 03:42 PM   #5
wootwoot
Drives: FRS
I was considering a MR125 in the event it makes a difference.
Old 11-14-2014, 06:30 PM   #6
MidnightRunner
MidnightRunner's Avatar
Actually the z came with 16" wheels. I've owned two fairlady z's and both had 16's stock.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 11-14-2014, 06:32 PM   #7
raven1231
Yeah, I have one in the driveway right now lol
Old 11-14-2014, 06:34 PM   #8
MidnightRunner
Nice! I loved those cars more than anything. Miss the car. Did NOT miss all the piping and boost leaks!
Old 11-14-2014, 06:41 PM   #9
raven1231
Yes, and absolutely no room in the damn engine bay to work on them...
Old 11-14-2014, 06:52 PM   #10
MidnightRunner
Haha so true. Although the spark plugs were easier to change compared to the brz. Maybe you could help the op with his project. Very very interesting how this shapes up.
Old 11-14-2014, 06:56 PM   #11
mav1178
mav1178's Avatar
Flat + thick backpad, or concave w/ spoke design that is meant to clear brake calipers.
See: TE37 vs TE37v. The same size/offset wheels in either design will clear, or not clear a brake setup.
An example of what different concave/backpad looks like:
In practice, it will be essentially how much distance is between the back of the spoke, vs where the brake caliper will sit. a brake setup with a 11" rotor vs 13" rotor make a difference.
-alex
Brake Fluid Swap (How Many Quarts) Apex_BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 07-01-2019 04:41 PM
Nissan 300zx brake upgrade anybody? Extreme Dimensions Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 12-31-2014 11:29 PM
E brake boot swap? Hardrock4445 NY / NJ / CT / PA 18 01-11-2014 12:10 AM
Daily drivers, do you swap street and track brake pads? qoncept Tracking / Autocross / HPDE / Drifting 31 06-26-2013 03:50 AM
E-brake handle/boot swap Hanakuso DIY (Do-It-Yourself) Guides 1 08-26-2012 03:02 AM
