C-Street AutoX
41K+ Miles No issues
My FR-S now has 41k miles...and it really doesn't need shit. My Koni shocks make some rattle/clunk like noises at very low speed on very bad roads, but that's to be expected I think.
I've done nothing so far except change the oil. Does anyone else have this kind of milage and what problems (if any) have they run into? Any reason to change the diff/trans fluid if it's shifting just fine? I have 41k miles since Feb 2013, and I do not drive the car for 4 months out of the year minimum. The car is run hard in the summer at several autocrosses, in the Solo Nationals. Does this put excess wear on the differential fluid? I'm more concerned the diff is working properly as the transmission is fine. I have a Cosworth Air filter, and already have a K&N ready to be put in. I run the Joe Gibbs 5w20 Synthetic every 5k miles, HKS oil filter. Did a quick search and didn't see anyone post any info for 40K + mile maintenance yet, so figured I'd ask if anything may need attention that I didn't think of. Car is due for an oil change, should I change it now before I the car sits for 4 months, or let the car sit and change the oil after the winter?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
| The Following User Says Thank You to SeanRTR For This Useful Post: | hmong337 (11-05-2014) |
Drives: Whiteout FR-S
I am about to hit 50,000 miles and I have also not run into any major issues. If you are autocrossing I would definitely recommend you change our your diff and transmission fluid. The diff fluid is so easy to change you might as well to avoid any wear and tear issues down the road.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
Over 41K as well, just been following subaru's maintanence plans. OP, you may want to do the 30k mile service....
Country Boy 4 Life
I am also at 41,000 miles. No problems! A few interior rattles...
I would change all your fluids next spring. Do you store your car inside or out? I wish I had a garage. |
C-Street AutoX
It's outside, but mostly covered parking...still gets partially snowed on with the wind. Just under a car port overhang at a crappy apartment complex.
28,000K here. Getting ready to do the trans and diff fluid. Nothing else but oil changes and a brake fluid swap..
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
34500, I have a fully modded car (vortech SC) and regularly HDPE. So far going well.
Some small things I had to address or will address: 1) Coil pack started going out so I replaced all spark plugs and coil packs 2) Rear passenger OEM Strut is leaking so I need a new set of those (I have RCE Yellow Springs) 3) I have leaks in all the CV Boots on both half shafts. Need to fix that 4) My OEM battery died long long ago; bad cell. Replaced with Diehard Platinum 5) I have a small oil seep in the timing chain cover on the driver side. 6) My belt is squeaking now
| The Following User Says Thank You to F1point4 For This Useful Post: | flippy (11-19-2014) |
^^ How tough is it to change the plugs? I've seen some people say it can't be done by a shadetree mechanic in his driveway.
#9 | |
Drives: '13 BRZ Ltd WRB
Next big maintenance is 60k. I'm just a few hundred miles shy of that myself. The dealer wants $675 for it, screw that! I already changed trans & diff oils, and just changed motor oil as well.
I also have a set of StopTech pads, some SS lines and new brake fluid sitting in my garage waiting for the day my stock pads even start to squeak. I don't think I've ever had pads last this long, but I guess that's what happens when they source brakes from cars that are at like 700 lbs. heavier. No way I'm going to pay the dealer that much to check some fluids and full a few zerk fittings. Complaint-wise, I've been noticing the rear shelf buzz more than usual, but I've also had the rear seat down for much longer than normal. Just too lazy to put it back up, maybe it helps hold the shelf cover in place. I've also had the HPFP replaced twice, really didn't make a difference either time, so I gave up on that "issue". Quote:
I recommend reading all the DIYs carefully, then eyeballing it to see if it'll work out for you and your meat hooks. I will probably pay my skinny friend to do this for me when the time comes.
#10 | |
Drives: BRZ DGM Limited
Isn't it time to change the plugs at 60K? Which officially requires lifting the engine? Maybe that is why the dealer is looking for $675. Still a lot of money. |
#11 |
Yeah, good call. Forgot that was a 60k thing...damnit.
#12 |
Actually given that the engine has to be lifted, I'm surprised its not more. Also, interesting that this happens just as the drivetrain warranty runs out.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#13 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
If you haven't done this already try your luck with trusted shops that work on our cars/Subarus. I am getting mine done and was quoted only 1.5hrs labor for the spark plugs (I did the engine and diff oil myself already)
Edit: I should also note the plugs themselves are about $25 a piece so even then your looking at probably around $250-$300 for plugs
| The Following User Says Thank You to finch1750 For This Useful Post: | 2point0 (12-11-2014) |
#14 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
At 36k I have a bad cv joint, replaced the sc belt as it was squeaking, changed the diff and trans fluid shortly after buying it, various interior noise (it's not a super luxury car so to be expected), rear endlink bolt (Perrin) disappeared while driving so needed a new one, oem tail lights leak but new thicker gaskets fixed it plus have Tom's now, supercharger needs a little oil every month or two, intercooler hose needed adjustment on the clamp as it was leaking. Aside from that I haven't needed to replace anything except oil. I've had it since August 2012. Trying to get the dealer to replace the cv joint but am putting the rear end back to stock so they will actually look at the car instead of saying your car has too many mods on it. Warranty will be up in August so need to convince them to fix it!
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| 2013 - MT - 18k miles - Issues. | tbrocato | Issues | Warranty | Recalls / TSB | 13 | 10-11-2014 10:49 AM |
| 2000 honda civic si 33k miles on body 3k miles with turbo kit | Anthony7515 | Cars for Sale/Trade | 3 | 07-28-2014 09:10 AM |
| Oft e85 issues | sosick | Software Tuning | 14 | 05-22-2014 05:40 PM |
| BC BR coilovers for sale. 3k miles on them with no issues at all! Just changing it up | NickFRS | Brakes, Suspension, Chassis | 11 | 03-14-2013 02:44 PM |
| more issues after CEL fix.. | DrewZ926 | Issues | Warranty | Recalls / TSB | 2 | 11-07-2012 08:15 PM |
