Old 11-04-2014, 10:56 PM   #1
Cal3000
Drives: Panda FR-S
Oil Leak at Camshaft Timing Controler
Looks like the sealant at the assembly blew out under the exhuast camshaft timer and now my oil is leaking. Anyone know what the repair bill on this will be? They will probably need to take the engine apart and reseal. To comfort ya'll, I'm boosted at 71k miles on my car.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 11-05-2014, 08:13 AM   #2
Thorpedo
The SquadWhisperer
I've been putting off getting the dealer to look at mine in an attempt to find others with this issue. Mine is on the other side but looks exactly the same. Are you sure its not actually leaking at the timing cover/block mating surface? Perhaps the dirt on the timing cover is just missing on the "bottom" of the curves due to gravity as opposed to it being washed off by the oil?
I know the dealers typically remove the engine to do the timing cover, not sure about the sensor.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 11-05-2014, 09:21 AM   #3
vgi
Drives: frs
Check this TSB:
http://www.ft86club.com/forums/showp...&postcount=187
Y don't you just trade it in for something else? Or maybe for a new '15 if you like it that much.
vgi is offline   Reply With Quote
Old 11-05-2014, 06:55 PM   #4
Ozzman
Drives: old
You sure it isn't oil blown out of that breather filter?
Ozzman is offline   Reply With Quote
Old 11-28-2014, 11:40 AM   #5
Astroboy
Astroboy's Avatar
Drives: None
@Cal3000 are you still driving it? That really sucks, I noticed leaking on my car on the opposite side of yours, and on only at 28k miles. 3k miles are with the avo kit.
Let me know if you get a quote please
Astroboy is offline   Reply With Quote
Old 11-28-2014, 11:59 AM   #6
blown
Drives: ft86
mine did the same. dealer wouldn't fix it until it leaked where puddles will form.
blown is offline   Reply With Quote
Old 11-29-2014, 03:03 AM   #7
Astroboy
Astroboy's Avatar
Drives: None
Did yours leak that bad?
Old 12-05-2014, 05:23 PM   #8
radroach
Drives: car
Discovered oil running out from underneath my car while it was raining. Ran papertowel underneath cam plate and there was some burned oil there. Going to make a call to dealership and see what they'll do.
Old 12-05-2014, 06:26 PM   #9
blown
Drives: ft86
not enough to cause puddles but enough to collect a WHOLE lot of dirt and black crud.. it will form a drop after every drive, and feel wet..
mine looked almost like the pictures..
Old 12-15-2014, 02:23 AM   #10
Astroboy
Astroboy's Avatar
Drives: None
Any updates on the car @Cal3000
Old 12-20-2014, 01:43 PM   #11
Cal3000
Drives: Panda FR-S
Haven't got it fixed yet. lol. Don't want to take it to the dealer as they will probably break something on the supercharger.
Planning to take it to a local tune shop. I told them the issue and they quotes me at $300 for the fix which I think is pretty cheap compared to what the dealer might charge.
The Following User Says Thank You to Cal3000 For This Useful Post:
Astroboy (12-23-2014)
Old 12-23-2014, 11:09 PM   #12
Astroboy
Astroboy's Avatar
Drives: None
Good quote if you ask me.. here's mine. I think my oil pan might be leaking as well. a buddy of mine is going to help me re seal the cam cover with a new gasket and Honda bond, and I am also going to have him help me with the oil pan. He said he wasn't going to charge me, but I told him I was going to pay him anyways. Favor for exchange of a favor is the way I see it. Gasket was 30 bucks, and job time is suppose to be only 2 hours. We were both puzzled about it only being a two hr job supposedly because we found it quite difficult to grasp; we think it might be a 3hour job. He charges 70 an hour and is a good friend. I trust him.
Old 07-02-2015, 01:11 AM   #13
Astroboy
Astroboy's Avatar
Drives: None
Turns out it was only leaking from the oil dipstick
Sent from my LG-D850 using Tapatalk
The Following 2 Users Say Thank You to Astroboy For This Useful Post:
IBill4You (07-02-2015), Ultramaroon (07-02-2015)
Old 09-19-2015, 01:58 AM   #14
Astroboy
Astroboy's Avatar
Drives: None
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
Different Camshaft Part numbers for 2014 model? brn12345 Engine, Exhaust, Transmission 2 04-21-2014 11:51 AM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 02:54 PM
