Drives: Scion FR-S
Too much oil
I just got my first oil change done at my local service center. I brought my own oil and I think they put in too much. I brought them 6 quarts of enous and they only returned maybe about 50- 100 ML back. Also I am not completely sure they drained all old oil since my engine wasnt fully warmed when I brought it to them.
Two Questions 1. How damaging is it to have over the 5.8 quarts? 2. Is it worth the hassle to get them to drain it? Last edited by MikeyBatz; 11-04-2014 at 11:46 AM. |
Drives: Exige S 240
How about checking your dipstick?
| The Following 2 Users Say Thank You to Guillaume For This Useful Post: | AZP Installs (02-17-2015), FT86Z (01-05-2016) |
Drives: Scion FR-S
Always when warmed.
| The Following User Says Thank You to Tcoat For This Useful Post: | Alltezza (02-20-2015) |
Young Blood
Drives: 2013 Red BRZ 2.0 Premium
I'd bet my booty that it'll be fine!
Now 1-2 quarts and I'd be worried about the crankshaft turning that into foamy milk! But it's most likely .3-.4 quarts over filled-- tops, that will burn off/not be an issue at all. When I worked on these, all the engines that took 5.8 qts were given 6 by lazy me. Usually after checking the dipstick, you'd be right on the max line anyway! |
Drives: Whiteout Scion FR-S
You may want to read 2 old threads I started a while back:
Factory Oil Fill Level 1st Oil Change Experience, Observations & a Surprise
| The Following User Says Thank You to Black Tire For This Useful Post: | Ultramaroon (11-04-2014) |
#10 |
I always put 6 quarts in when I change my oil. A little extra won't hurt.
Pat |
#11 |
Drives: Slow
I don't believe these motors on average consume noticeable oil between oil changes. But it's a good practice to check your oil regularly and consistantly. I would not count on a dealer to notify you of any oil consumption issues if they should arise.
#12 |
Drives: Toyota GT86 Satin-White-Pearl
Too much oil=hot running engine
From my experience the engine ran much hotter when overfilled.
The engine bay was very hot and oil/intake temperatures were much higher on load and idle. There was also unburned oil from the exhaust and the engine felt quite rough. That was only 0.2 0.25 quarts over max. After two days i removed that amount and a bit more. All temperatures went down immediately and the engine ran fine! Now i prefer an oil level in/over the mid range of the dipstick. |
#13 |
Drives: JRSC'd Asphalt FR-S
check dip stick, if its way over then u can just let some out and refill.. my friend had it way over for the whole interval from dealer. never checked it.. car not totalled yet lol
#14 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
I always overfill by 50-100 mL, better to overfill a little than not put enough. Anything more than 3/4 of a quart I would be worried, other than that you should be fine.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
