Old 11-04-2014, 10:34 AM   #1
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
Too much oil
I just got my first oil change done at my local service center. I brought my own oil and I think they put in too much. I brought them 6 quarts of enous and they only returned maybe about 50- 100 ML back. Also I am not completely sure they drained all old oil since my engine wasnt fully warmed when I brought it to them.
Two Questions
1. How damaging is it to have over the 5.8 quarts?
2. Is it worth the hassle to get them to drain it?
MikeyBatz is offline   Reply With Quote
Old 11-04-2014, 10:55 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i wouldnt worry too much but i will watch and tell them how much oil needs to go in for next oil change.
Old 11-04-2014, 10:59 AM   #3
Guillaume
Guillaume's Avatar
Drives: Exige S 240
How about checking your dipstick?
Guillaume is offline   Reply With Quote
The Following 2 Users Say Thank You to Guillaume For This Useful Post:
AZP Installs (02-17-2015), FT86Z (01-05-2016)
Old 11-04-2014, 11:07 AM   #4
MikeyBatz
MikeyBatz's Avatar
Drives: Scion FR-S
I will once I get to somewhere that is level. Do you recommend checking when the engine is cold or warmed up?
Old 11-04-2014, 11:20 AM   #5
Always when warmed.
Alltezza (02-20-2015)
Old 11-04-2014, 11:24 AM   #6
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Yeah, warm, 5 minutes after shutting down the engine.
Old 11-04-2014, 11:33 AM   #7
dpesce
Young Blood
dpesce's Avatar
Drives: 2013 Red BRZ 2.0 Premium
I'd bet my booty that it'll be fine!
Now 1-2 quarts and I'd be worried about the crankshaft turning that into foamy milk! But it's most likely .3-.4 quarts over filled-- tops, that will burn off/not be an issue at all. When I worked on these, all the engines that took 5.8 qts were given 6 by lazy me. Usually after checking the dipstick, you'd be right on the max line anyway!
dpesce is offline   Reply With Quote
Old 11-04-2014, 12:54 PM   #8
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
You may want to read 2 old threads I started a while back:
Factory Oil Fill Level
1st Oil Change Experience, Observations & a Surprise
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
Ultramaroon (11-04-2014)
Old 11-04-2014, 05:08 PM   #9
frs10
Drives: tezla
its less than 5.8
frs10 is offline   Reply With Quote
Old 11-04-2014, 05:48 PM   #10
fasteddy
I always put 6 quarts in when I change my oil. A little extra won't hurt.
Pat
fasteddy is offline   Reply With Quote
Old 11-04-2014, 09:17 PM   #11
civdaddy
Drives: Slow
I don't believe these motors on average consume noticeable oil between oil changes. But it's a good practice to check your oil regularly and consistantly. I would not count on a dealer to notify you of any oil consumption issues if they should arise.
civdaddy is offline   Reply With Quote
Old 02-15-2015, 10:46 AM   #12
Hector
Drives: Toyota GT86 Satin-White-Pearl
Too much oil=hot running engine
From my experience the engine ran much hotter when overfilled.
The engine bay was very hot and oil/intake temperatures were much higher on load and idle.
There was also unburned oil from the exhaust and the engine felt quite rough.
That was only 0.2 0.25 quarts over max.
After two days i removed that amount and a bit more.
All temperatures went down immediately and the engine ran fine!
Now i prefer an oil level in/over the mid range of the dipstick.
Hector is offline   Reply With Quote
Old 02-15-2015, 05:00 PM   #13
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
check dip stick, if its way over then u can just let some out and refill.. my friend had it way over for the whole interval from dealer. never checked it.. car not totalled yet lol
Old 02-15-2015, 05:04 PM   #14
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
I always overfill by 50-100 mL, better to overfill a little than not put enough. Anything more than 3/4 of a quart I would be worried, other than that you should be fine.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
