Old 10-30-2014, 04:29 AM   #1
notout86
Drives: GTS 86 auto
most recent ECU software
Does anyone know if the 2015 model comes with a newer ECU software version to the 2014?
I am having a service done soon and will have it done.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 10-30-2014, 05:29 AM   #2
steve99
Yes they do
Manual MY2014 ZA1JA01G MT 2015 ZA1JD00G
Auto MY2014 ZA1JA01I Auto 2015 ZA1JE00I
However I dont think they are compatible.
Tried the D00G rom in my late 2013 (My14) and thew CEL codes re communication with Dash Cluster and ECU Alternator control codes. Car ran ok if Dash Code P0155 disabled but switched back to original rom just to be safe. Suspect 2015 has some changes to dash software/hardware and possibly alternator.
also the dealers will not flash your car unless there is a service bulletin (TSB) instructing them to do so
Old 10-30-2014, 06:57 AM   #3
ZZT86
ZZT86's Avatar
Drives: BR86
Like DI issue previously ? Then chances are slim ?
ZZT86 is offline   Reply With Quote
Old 10-30-2014, 07:17 AM   #4
steve99
I think the 700G/I ,900G/I A00G/I guys can get a flash to A01G/I as their was a TSB to flash earlier rom's to A01G/I due the DI seal issue and idle issues with those early roms but even then dealers seem reluctant to do it unless you whinge and bitch.
Their is apparently a A02G rom around but no one has pulled one yet
Old 10-30-2014, 02:18 PM   #5
notout86
Drives: GTS 86 auto
Sometimes you do need to persist with dealers over these types of issues.
e.g. the standard settings for the climate control in auto is such that it will go into recirculate mode automatically and inappropriately and seemingly at random and we did not appreciate the stuffiness. Not only that, the distraction switching off recirculate is a bit dangerous.
The dealer said there was nothing that could be done. Then I found this not to be correct and told the dealer. Same answer.
I got the name of the dealer who COULD do it and got it done for $50 (and they washed and vacuumed).
Old 11-06-2014, 01:28 AM   #6
n0m0h0s
n0m0h0s's Avatar
Drives: #2148 frs 10 series
Send a message via AIM to n0m0h0s
Did the reflash on my car for idle issue, now my car's response has gone down. Checked the newer '15 FRS and they already have these programmed at factory. Idle issue is gone but my car feels slower at dead stop. If I would have known, I wouldn't have updated it; reflash not worth it!!!! Don't do it people!!!
n0m0h0s is offline   Reply With Quote
Old 11-06-2014, 02:45 AM   #7
Poodles
Drives: 2015 Series.Blue
More likely to be the ECU hasn't relearned the pedal position.
Old 11-06-2014, 05:25 AM   #8
aagun
Drives: 86
the car ECU normally clean the LTFT and remap it again . so it take a while to back like before #
aagun is offline   Reply With Quote
Old 11-06-2014, 06:02 AM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
Don't worry, your car will be fine in a few days. Make sure to give it plenty of varied driving @ different speeds. ECU needs to relearn fuel trims & pedal calibration.
Old 11-06-2014, 10:15 AM   #10
AsianStyle
AsianStyle's Avatar
Drives: Whiteout FR-S MT
Should read/learn more about the car before going on rants. As others mentioned the car is in relearning mode. If you pull the battery for too long it will do the same. You can just drive it and wait or you can try this:
http://www.ft86club.com/forums/showp...69&postcount=3
AsianStyle is offline   Reply With Quote
BRZedit recent updates CARNZ Software Tuning 1 04-22-2014 12:04 PM
Recent Thread List Anthony Site Announcements / Questions / Issues 0 07-21-2013 10:24 AM
Gauging recent OTD price on BRZ crazyprac Mid-Atlantic 12 03-13-2013 08:39 PM
Recent Purchase TheGuyWithTheFireStorm Scion FR-S / Toyota 86 GT86 General Forum 21 11-20-2012 02:57 PM
Recent car accident Sea1monkey2 Other Vehicles & General Automotive Discussions 19 06-21-2011 08:27 AM
